1980 924 ignition timing
Dltfam51
PostPosted: Fri Oct 04, 2019 6:05 am    Post subject: 1980 924 ignition timing Reply with quote
I bought a 1980 924. Car runs good just had few starting problems.
how can i find out if the engine matches the body numbers; So I can be sure on the correct ignition timing ,
Svobodin
PostPosted: Fri Oct 04, 2019 6:52 am    Post subject: Reply with quote
You could just time it with a timing light.
As far as I know, with the normally aspirated 924, there weren't many (if any) changes to the engine.
You could possibly have a non-stock distributor, in which case it woulf be best to use a timing light anyway.
safe
PostPosted: Fri Oct 04, 2019 9:51 pm    Post subject: Re: 1980 924 ignition timing Reply with quote
Probably fuel issues.
You can't. Not even Porsche have records to confirm "matching numbers".
