nivekrs
Posted: Sat Jul 20, 2019 2:51 pm Post subject: 1982 924 na-Distance to valve centers from intake ports |
| Can anyone tell me the distance to valve centers from the intake ports on the cylinder head of a circa 1982 924 na. Or even just the measurement across the bottom of the cylinder head. (Short side) Mine is currently in the machine shop and I am trying to make some calculations for a manifold I am fabricating. I’m trying to calculate 200 mm minimum distance from the injector in my itb to the valve center and adjust the length of the manifold runners accordingly. Thanks for any info. |
Joined: 08 Jun 2010 Posts: 1247 Location: Maysville, Colorado
Posted: Sat Jul 20, 2019 10:29 pm Post subject: |
I have some molded rubber intake ports that I made when working on porting the NA head. Can easily go in a USPS flat rate box and you can measure it yourself. _________________ Mike
