Raize
Posted: Fri May 31, 2019 4:57 am Post subject: 931 S1 Boost retard |
Does anyone have the curve for a RoW S1 931 ignitions vacuum/boost advance/retard?
Failing that, does anyone know the maximum amount of degrees of boost retard that is applied, and how many PSI of boost it takes to reach that maximum value? |
Raize
Posted: Fri May 31, 2019 11:03 pm Post subject: |
There's a curve for USA 931 but not for RoW. Not sure it's a safe assumption that they have the same curve given that the USA model had only 140hp and the RoW 170hp.
Not sure it's really relevant anyway, I was looking at swapping a 931 vacuum can onto a 924 distributor to get boost retard for a supercharger but they're horribly expensive and/or NLA. There doesn't seem to be a cheap option for this.
I wonder if the vacuum can is adjustable in any way. If I could add 5-10 degrees more vacuum advance, pull 5-10 degrees from the static timing, and use manifold instead of ported vacuum to keep a decent idle then it would achieve the right effect.
With the prices of 924 bits these days I don't really want to start drilling into vacuum cans though. The days of this being a cheap car to get parts for seem to be gone.  |
Posted: Sat Jun 01, 2019 4:10 am Post subject: |
Aldon Automotive can make modify a distributor to any advance/retard curve within reason. If not going stand-alone ecu route you could take a look at 123ignition dizzies. Either their stock bodies or the Mittelmotor option which are both programable with boost input. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
