Rboepple
Posted: Mon Oct 01, 2018 11:27 am Post subject: New project could use help |
My name is Rick I'm new to workinh on porsches if you could help me out I have a 1978 924.Ok so here is what ive done checked spark checked the fuel pump its working, checked vacume all good all hoses are new the boot from the intake to the air meatering unit good and tight and fuel diz rebuilt . Now what I have observerd. When trying to turn the car over no start because it cant pull the aire meatering unit oppen. But if I lift it open than it starts I have to keep it open for it to run meatering unit isnt stuck when I crank the plunger is holding the unit down. I think its because there is to much presure I experimented with this I took the banjo from the cold start where it goes into it and bypassed it straight to the return hose after doing that it ran but with low presure so it was excessively rich I tested the cold start valve.12 v and it opened so I'm not sure why it's causing so much presure in the dizzy to hold down the meatering unit _________________ 78 924
KDJones2000
Posted: Mon Oct 01, 2018 2:16 pm Post subject: |
Dude, buy some punctuation.
It is not worth the bother, if you aren't willing to take the time to make your post readable. _________________ 1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S |
Rboepple
Posted: Mon Oct 01, 2018 2:34 pm Post subject: |
Why would you bother getting on here to tell some one there gramer isnt so good thanks for your help.... _________________ 78 924 |
Posted: Mon Oct 01, 2018 5:03 pm Post subject: |
You messed up the dizzy rebuild and now its not giving out enough fuel.
Or in the process of rebuilding, you messed with the fueling adjustment screw and now you're either getting too much or to less fuel. _________________ Supercharger and EFI kits
Rboepple
Posted: Tue Oct 02, 2018 12:03 am Post subject: |
Ok thank you I'll pop it back off and order a rebuild and go threw it once more _________________ 78 924 |
Posted: Tue Oct 02, 2018 6:29 am Post subject: |
If the car runs when you hold the plate by hand then try increasing the mixture using a long allen key and turning clockwise, look in the haynes for mixture setting procedure.
Just give it half a turn and try starting it again, if it improves but not solves the situation, then another half a turn and so on. _________________ Supercharger and EFI kits
Ian89C4
Posted: Wed Oct 03, 2018 10:24 am Post subject: |
Agree with Morghen. I would also get a cis pressure tester ( or make one...a few how to's on the board). That way you can tell what your pressure is looking like...then you can diagnose the dizzy vs. the wur.
Good luck! _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Rboepple
Posted: Wed Oct 03, 2018 10:31 am Post subject: |
I appreciate the help guys. And today I realized that when I rebuilt the dizzy I didn't do the presure regulating neadl I remember the plunger was stuck good at wot so I wonder if the neadle could be stuck shut and causing to much presure holding the air meaturing plate down thoughts... And yes I will get a presure tester _________________ 78 924 |
Rboepple
Posted: Sun Oct 07, 2018 5:08 pm Post subject: |
So I cleaned out the wur and cleaned out the dizzy car will run but very laybored I think its because the dizzy is leaking out fuel ive ordered a proper rebuild kit only thing I'm not sure if I can use a sealent or if it's just sapose to be all metal on metal _________________ 78 924 |
Posted: Mon Oct 08, 2018 4:08 am Post subject: |
Use Locktite 542 on both sides of the metal plate. Spread very thinly with the edge of a razor blade and don't block the tiny holes in the plate. _________________ 1979 924 NA race car H-Prod SCCA
Rboepple
Posted: Mon Oct 08, 2018 4:35 am Post subject: |
Ok thank you _________________ 78 924 |
Rboepple
Posted: Mon Oct 08, 2018 5:10 am Post subject: |
Also should I let it dry or put it straight togeather _________________ 78 924 |
Posted: Tue Oct 09, 2018 12:59 am Post subject: |
After you spread it (very thin on both sides) you can bolt the distributor together. There is curing time for the sealant after assembly - I believe it is 24 hours. I don't have the instructions handy. _________________ 1979 924 NA race car H-Prod SCCA
Rboepple
Posted: Tue Oct 09, 2018 2:11 am Post subject: |
Ok did porsche or bosch do this during assembly to keep them from leaking? _________________ 78 924 |
