Mskeet
Joined: 23 Jun 2018 Posts: 36 Location: Buckinghamshire
Posted: Wed Aug 15, 2018 6:48 am Post subject: Headliner removal help |
I want to replace my headliner. I have a sunroof car. I need to remove the trim panel that the sun visors sit on, how is this achieved please, do I need to remove the A post capings too?
Any help greatfully recieved. _________________ Lover of all things Porsche
1968 912
1988 924S |
Ian89C4
Posted: Wed Aug 15, 2018 12:43 pm Post subject: |
Yes, you will need to remove the front trim, both side trims and the rear. You may be able to get away with leaving the A pillar trims in place.
You will also need to pull the front and rear mounting points for the targa top latches as well as the body seal for the targa top.
To remove the front trim piece start by pulling the sun visors, should be two or three screws per. You will have to rotate them to kind-of wind them out of their holes. You will see once they are loose. Don't pull on them, will most likely tear the trim piece. Then take out the interior light. Should just pup out. From there I believe the side trim pieces come off and the front piece should come down. There may be one or two more screws I'm forgetting about, but they'll be noticeable.
Main rule of thumb is don't try and yank things off. If they don't fall right off there is a screw still in place. Look for it and be careful.
Good luck! _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
Mskeet
Posted: Thu Aug 16, 2018 4:36 am Post subject: Many thanks |
Great. I have bought a new rear piece and recovered it. Nice to know that the front trim piece is held in by the sun visors or something below that.
Many thanks. _________________ Lover of all things Porsche
1968 912
1988 924S |
