Johnparmenter82
Joined: 11 Sep 2016 Posts: 12 Location: Rochester, new york
Posted: Mon Aug 06, 2018 8:14 am Post subject: Temp gauge not working |
I did a full engine rebuild....finally finish but the temp gauge is not working. Is it most likely the sensor behind the head? _________________ Johnparmenter82 |
Ian89C4
Posted: Mon Aug 06, 2018 11:36 am Post subject: |
If it was working prior to the engine rebuild I would say yes. Did you clean the temp sender? The plastic can crack on the outside and I have found different readings from the ones with the cracked plastic.
Cheers _________________ Ian Edgerly
North Carolina
Current:
1980 924 Euro ("Wahala") |
peterld
Posted: Mon Aug 06, 2018 7:50 pm Post subject: |
Plus check your wires thoroughly.......just been through all of that! _________________ 80/81 932/8 ROW |
peterld
Posted: Mon Aug 06, 2018 7:51 pm Post subject: |
Johnparmenter82
Posted: Sat Sep 01, 2018 9:40 am Post subject: |
Bad connection...problem solved! _________________ Johnparmenter82 |
