*URGENT* Info Needed Please
Kenodog
PostPosted: Thu May 31, 2018 11:21 pm    Post subject: *URGENT* Info Needed Please Reply with quote
I got a call from the shop building Olive's new motor and the mechanic asked me for the diameter of the rod and block bearing surfaces. I have the journal diameters but he needs the OD sizes where the bearings fit onto. The factory manual does not state this info and I cannot actually think why he would need it except to be able to calculate bearing play...
Anyone ?
Lee
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
PostPosted: Thu May 31, 2018 11:30 pm    Post subject: Reply with quote
Somebody with an open block may be able to help if they had the caps and the right measurement equipment.
I can get you the rod big end diameters(where the bearings go) but I cant help you with the block dimensions.
Kenodog
PostPosted: Fri Jun 01, 2018 12:41 am    Post subject: Reply with quote
Thanks brother that would be helpful. The only reason I can think he would need this is because of the clearance tolerances for the bearing caps. Never been asked this before.
Leg
1981 931, Sabine
2024 KLX300
2024 KLX140
Brockoli
PostPosted: Fri Jun 01, 2018 12:47 am    Post subject: Reply with quote
I have my '79 block that I could measure. The block was align honed when I rebuilt it. Not sure if that makes a difference. I only have calipers to measure. Would that be accurate enough?
'80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
25% of a '87 944 Chumpcar http://straightpipe.ca/forums/showthread.php?t=2454
'79 924 Sebring Edition(Sitting)
Kenodog
PostPosted: Fri Jun 01, 2018 1:21 am    Post subject: Reply with quote
Thanks guys but I found the info. Helps to have your glasses on when reading tech manuals lol !
Leigh
1981 931, Sabine
2024 KLX300
2024 KLX140
