fron rear axles weights?
musicalannette
PostPosted: Thu May 10, 2018 2:28 am    Post subject: fron rear axles weights? Reply with quote
Hi.
One thing I didn't do I meant to do before the car was written off was take it to a weigh bridge.
Does anyone have the weight of the car front in kg's and rear in kg's.
Jus by driving each end on to a weigh bridge?
I thought this might be slightly different for different models and gearboxes.
Thanks.
I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737.....
PostPosted: Thu May 10, 2018 3:29 am    Post subject: Reply with quote
We scale ours regularly; weights are in pounds:
https://www.facebook.com/photo.php?fbid=10203178754744543&set=pb.1678056378.-2207520000.1525886882.&type=3&theater
PostPosted: Thu May 10, 2018 10:03 pm    Post subject: Reply with quote
Additional info... note that the scale numbers posted are without driver, gutted car with cage, approx 3/8 tank of fuel. Things even out side-to-side better with the driver installed.
Also note that we've typically found the racecar to be 49/51% front/rear bias, due to the lack of interior... whereas when I scaled my 82 931 ages ago I found it more like 51/49% front/rear - though at the higher weight with interior etc.
HTH...
