Haed gasket
toast54
PostPosted: Thu Oct 26, 2017 10:55 pm    Post subject: Haed gasket Reply with quote
Well, after all I've done to get this 924S running, it seems I have a leaking head gasket..in a perfect world I would replace it, but it's not feasible at this time. I don't have coolant in my oil or oil in my coolant and it isn't overheating nor is there any gas bubbling in my coolant reservoir. I've pulled plugs and #1&#4 are definitely "steam cleaned". My question is, would there be a head gasket sealant that might possibly work? Any input would be appreciated. I am going to run cylinder compression and coolant system pressure tests this weekend
toast54
PostPosted: Sat Nov 11, 2017 5:53 am    Post subject: Reply with quote
Not a head gasket, fortunately. There are some theories being bandied about. Water in gas tank is the prevailing one
PostPosted: Sat Nov 11, 2017 11:03 am    Post subject: Reply with quote
If your only conditions are white plugs, perhaps you could suspect your injectors or fuel distributor. Water would be equally distributed (pun intended).
toast54
PostPosted: Fri Nov 17, 2017 12:00 am    Post subject: Reply with quote
Seems to be sorted out. There's a very small amount of smoke from the tailpipe but nothing like before. I still plan on sending the injectors to Witchhunter performance this winter. With any luck I can also work on other things I had planned for the "offseason"
