Kenodog
Posted: Wed Sep 20, 2017 1:19 am Post subject: Mittlemotor Programmable Dizzy Reviews ? |
Other than CarreraRSR has anyone else bought this little unit ? Just owndering if it would be worth the big bucks to put into Olive's new motor ? Realistically what kind of HP gains can you get with it on a relatively stock motor ?
Leigh _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
Raceboy
Posted: Wed Sep 20, 2017 2:42 am Post subject: |
What kind of money are we talking about? _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Kenodog
Posted: Wed Sep 20, 2017 3:37 am Post subject: |
755 Euro ex. VAT to Kanada from Mittlemotor.
Lee _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Wed Sep 20, 2017 5:22 am Post subject: |
Several turbos and CGT’s running them in the UK and wider. Mittelmotors option is pricey considering the electronics inside. But the do s nice job making the electronics fit a stock dizzy body so it looks proper oem.
Only issue I have heard of is someone who bought theirs from 123ignition direct. After some time trying to make it work, 123ignition said it will not work for a 924 turbo!! No idea why not given mittelmotors version works?
However, I’m sure raceboy may be able to come up with an alternative solution y _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Wed Sep 20, 2017 5:27 am Post subject: |
Not sure the cars that have added it were looking for bhp gains. They were swapping out dead crank sensors on S2’s. And CGTS on the most part. Michael at mittelmotor will tell you what, if any gains can be had. Smoother running is the most noticeable feature for me. Before you turn up the boost!! _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Kenodog
Posted: Wed Sep 20, 2017 6:47 am Post subject: |
I had just assumed you would reap some bhp benefits seeing as the factory set up is not exactly 'tunable' by today's standards. Can you not optimize the fairly conservative ignition curve to see some extra juice ?
Me _________________ 1979 Euro 931, Olive
1981 931, Sabine
2024 KLX300
2024 KLX140 |
Posted: Wed Sep 20, 2017 7:53 am Post subject: |
You can. But it’s timing and advance/retard optimisation is best exploited with IC and more boost. On stock boost I only noted smoother running and crisper throttle response. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Johann
Posted: Wed Sep 20, 2017 9:36 pm Post subject: |
Interesting subject, does this setup eliminate the DITC and NLA Flywheel sensor? And if so, how does it compensate for boost?
I am seeing all kinds of possibilities combined with FrankenCIS  |
Pascal924
Posted: Sun Oct 01, 2017 9:18 pm Post subject: |
I used the 123 on my 924 turbo. Its a type 1 engine with gt intercooler.
Works perfect. |
Posted: Sun Oct 01, 2017 10:54 pm Post subject: |
I wish it had temp input as the ditc, is there any detailed technical specs on it anywhere? _________________ 1980 924 Turbo
Posted: Sun Oct 01, 2017 11:38 pm Post subject: |
The laptop software outputs a temperature, so something in the dizzy is taking a stab at temps. Not sure if it’s heat soak or vacuum line air temp. Mine shows circa 30-40deg. Too low for head temps and too high for intake air temp. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Raceboy
Posted: Mon Oct 02, 2017 4:09 am Post subject: |
| Carrera RSR wrote: | | The laptop software outputs a temperature, so something in the dizzy is taking a stab at temps. Not sure if it’s heat soak or vacuum line air temp. Mine shows circa 30-40deg. Too low for head temps and too high for intake air temp. |
In that case it is possible to unsolder the NTC thermistor in the dizzy and connect proper air temp sensor in the intake. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
gegge
Posted: Wed Oct 04, 2017 5:03 am Post subject: |
| Pascal924 wrote: | I used the 123 on my 924 turbo. Its a type 1 engine with gt intercooler.
Works perfect. |
Interesting! Did you convert the stock distributor or modifed the 123 unit? Which one did you buy? _________________ Carl Fredrik Torkildsen
Posted: Wed Oct 04, 2017 5:22 am Post subject: |
Im pretty sure i read some where here about the difference between the 123 and mittlemotor version? Anyone remembers? _________________ 1980 924 Turbo
Pascal924
Posted: Sun Oct 08, 2017 5:20 am Post subject: |
I send my original dizzy to 123.
They convert it.
I just modified a bit the curve, but Notting special.
Runs perfect. |
