Paulyy
Posted: Sun Jul 23, 2017 7:04 pm Post subject: Motec m400 using the distributor sensor? |
I have a motec m400 that I'll be using for my track car project. I don't have a loom for it just yet so I cannot test it if this will work. But obviously I need to tell the motec the position of the engine and that's done with a crank sensor..
I saw somewhere on this forum that someone used the original distributor and locked the internals and use that to give the signal to the ecu for crank position.
I'm not sure with the proper terms, but will this be possible?
Other options will be a 36-1 trigger wheel. But I want to know if using the dizzy is a viable option with a motec.
Thanks. _________________ 924 - Race car project in the works.
http://www.924board.org/viewtopic.php?p=384410#384410
951 - 400whp. |
RC
Posted: Tue Jul 25, 2017 10:58 pm Post subject: |
Definitely doable, no worries.
Have used locked mechanical dizzy with programmable ignition and megasquirt sucessfully before going toothed wheel CNP. Dizzy was then used by another board member with his MSD.
http://www.924board.org/viewtopic.php?t=37897
Ive posted dizzy info and pictures on here somewhere previously. The resolution is not as good as with a toothed wheel, only 180* per 720* engine cycle but M400 has a good fast processor and confugurable signal input trigger. Easiest way to get the system up and running, then can progress to toothed wheel later. _________________ World`s quickest 924 2L slushbox
Paulyy
Posted: Tue Jul 25, 2017 11:12 pm Post subject: |
| RC wrote: | Definitely doable, no worries.
Ive posted dizzy info and pictures on here somewhere previously. The resolution is not as good as with a toothed wheel, only 180* per 720* engine cycle but M400 has a good fast processor and confugurable signal input trigger. Easiest way to get the system up and running, then can progress to toothed wheel later. |
I've seen that thread previously.
That's what i was planning on doing. use the dizzy first. get it running. get some ignition maps and fuel maps in. then slowly perfect the system.
Where in Aus are you? Also do you mind sharing some ignition & fuel maps?
Thanks! _________________ 924 - Race car project in the works.
951 - 400whp. |
RC
Posted: Tue Jul 25, 2017 11:22 pm Post subject: |
| Paulyy wrote: |
Thanks! |
Yes, thats how I set up MS, first NA then with SC then keep on developing and more boost, 911 style.
I`m in Adelaide. Happy to share maps, have some from different stages, good starting point anyway.
Is your car NA or turbo? _________________ World`s quickest 924 2L slushbox
Paulyy
Posted: Tue Jul 25, 2017 11:26 pm Post subject: |
| RC wrote: | | Paulyy wrote: |
Thanks! |
Is your car NA or turbo? |
Ah, from Melbourne. My 951 came from Adelaide though.
NA at the moment. turbo in the future. This will actually be going onto a road going car then once it's perfected and the track car build is done, i'll be transferring the motec to that engine which will be boosted but keeping the stock compression ratio. _________________ 924 - Race car project in the works.
951 - 400whp. |
RC
Posted: Tue Jul 25, 2017 11:38 pm Post subject: |
Just had another quick read through your build thread, sorry I couldn`t recall much. Bastard about the pictures! _________________ World`s quickest 924 2L slushbox
Paulyy
Posted: Tue Jul 25, 2017 11:46 pm Post subject: |
Yep. Photobucket just killed a lot of forums. I need to find a new host.
I haven't gotten much further with the track car yet. Just a lot of sanding and cutting.
PM me your email address, i'll send you an email _________________ 924 - Race car project in the works.
951 - 400whp. |
Raceboy
Posted: Thu Jul 27, 2017 4:59 pm Post subject: |
You cannot use just the distributor unless you plan to keep the distributor for spark because ECU needs to know if the crank is TDC for cyl1+4 or 2+3, without missing tooth it does not know and therefore you need distributor that physically distributes spark.
If you are going to use direct ignition then you need missin tooth wheel.
I suggest do it right, it is quite easy to put 36-1 or similar to crank pulley (to the inside of the alternator belt pulley). _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Posted: Thu Jul 27, 2017 11:40 pm Post subject: |
| Raceboy wrote: | | I suggest do it right, it is quite easy to put 36-1 or similar to crank pulley (to the inside of the alternator belt pulley). |
Trigger wheel:
http://garage.ideola.com/prod-EFISolutions.html#36-1TW
I now also have a bracket for a threaded body style VR sensor. Need to get pix and pricing up on the site, but PM me for details. _________________ erstwhile owner of just about every 924 variant ever made |
Paulyy
Posted: Thu Jul 27, 2017 11:42 pm Post subject: |
| ideola wrote: | | Raceboy wrote: | | I suggest do it right, it is quite easy to put 36-1 or similar to crank pulley (to the inside of the alternator belt pulley). |
Trigger wheel:
I now also have a bracket for a threaded body style VR sensor. Need to get pix and pricing up on the site, but PM me for details. |
Yeah i know you've got the wheel, didn't know you had a bracket, and i'll be ordering them on a few week I'll email you when it's time.
951 - 400whp. |
