Dutch924-racer
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Fri Jul 21, 2017 3:26 pm Post subject: check valve vacuum 931 S2 ? |
Does a 931 S2 (ROW) have a check valve in the vacuum lines? (except for the one in the brake booster)
If yes, where should it be ?
 _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Forge recirculation valve + boost controller |
Posted: Fri Jul 21, 2017 5:17 pm Post subject: |
As far as I know only the S1 has this. _________________ Supercharger and EFI kits
Posted: Fri Jul 21, 2017 6:12 pm Post subject: |
Correct. Only the S1 has vacuum/retard via the distributor and the red/white check valve is required to manage the pressures. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
