Texor Guest
Posted: Tue Sep 10, 2002 11:03 pm Post subject: |
| in my search for an engine i found a chevy 305 overhauled with 0 miles. what is the hp and is that a good swap? |
924 turbo Guest
Posted: Tue Sep 10, 2002 11:09 pm Post subject: |
It's a good swap if you've got $3000+ laying around. Unless, of course, you've got access to a machine shop, are an experienced welder, and live at a junkyard.
Jon Furst
'80 924 (daily driver)
'81 931 (never-ending project)
[ This Message was edited by: 924 turbo on 2002-09-10 23:10 ] |
Texor Guest
Posted: Wed Sep 11, 2002 12:25 am Post subject: |
its 500 bucks, saw it in paper.
my friend owns a machine shop
[ This Message was edited by: Texor on 2002-09-11 00:26 ] |
924 turbo Guest
Posted: Wed Sep 11, 2002 5:57 am Post subject: |
So, that's a complete engine, pan to air cleaner, freshly rebuilt for $500? Does it come with all the accessories too? Even if it did, which it probably doesn't, you still have to mount it to something. Renegade Hybrids used to sell a kit to mate a Chevy small block engine to the 924 drivetrain. It was $2000. It also didn't come with anything related to the cooling system, throttle linkage, exhaust, wiring, etc. When I said that you'd need $3000, I meant from start to finish, including the cost of the engine. Chances are, you'll spend more than that, too. What do you need more power for anyway?
Lizard Guest
Posted: Thu Sep 12, 2002 1:29 am Post subject: |
if he is saying $500 rebuilt it is probably not a professional rebuild and it has never been fired up to see if it even runs spend the extra money and get one that is professionally rebuilt and run and you had damn well be a good backyard mechanic
Cbass Guest
Posted: Thu Sep 12, 2002 9:34 am Post subject: |
Here's an idea I've been toying around with for engine conversions on the 924. The snailshell torque tube is shorter, right? How much shorter?
What I want to try is getting a 944 inner shaft, and cutting off the clutch end and remachining it for Ford splines. Then putting the 944 driveshaft in a 931 snailshell torque tube, and attaching it to a Ford V8 and clutch.
I wanted to do this with a RX7, but it would be much easier with a 924.
Lizard Guest
Posted: Thu Sep 12, 2002 10:46 am Post subject: |
well just dont talk about it cbass do it, LOL
