daniel
Joined: 18 Jun 2009 Posts: 686 Location: Sydney, Australia
Posted: Mon Nov 02, 2015 2:38 pm Post subject: |
I called these guys once for a price to wheel align my 924. After receiving the price I needed to clarify if the price was infact to buy the wheel aligning machine... _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
gegge
Posted: Mon Nov 02, 2015 10:41 pm Post subject: |
767hp... _________________ Carl Fredrik Torkildsen
Scott Sanda
Posted: Tue Nov 10, 2015 1:34 pm Post subject: |
Notice the intake and exhaust, they are swapped. I wonder how they timed it out. Does the head fit backwards, or did they need to re machine the ports....
I suppose nothing says you can,t have the intake cam on the right side of the motor, if you get everything correct.
Creates an interesting exhaust path, doesn't it? |
Posted: Tue Nov 10, 2015 1:38 pm Post subject: |
They likely used a 928GTS head which is very similar and has one head that is mirrored. _________________ Stefan
Posted: Wed Nov 11, 2015 3:44 am Post subject: |
http://rennlist.com/forums/944-turbo-and-turbo-s-forum/899905-the-rp968-it-s-a-bit-of-a-thing.html
They actually put the head on backwards..
| thingo wrote: |
If you look closely you can see the new oil drains so we can switch the head around. We machined off the sprockets on the cams to give us more clearance.
Bleeders on what is now the high side of the head.
Intake
| thingo wrote: | Thanks guys, rotating the head was not overly complicated, just the oil and water paths, it meant we could make a better exhaust manifold and we now have the hot and cold sides of the engine separated.
The intercooler radiator combo is from pwr, intake temps were 5 degrees above ambient
Custom engine and turbo mounts
_________________ 80 Turbo - Slightly Modified |
Posted: Sun Mar 17, 2019 8:42 am Post subject: |
https://www.youtube.com/watch?v=J87SVqG18sY
3000HP & 10,500RPM from a 4 cylinder billet block that weighs only 106kg, who doesn’t like the sound of that possibility! Oskar Elmgren from Elmer Racing talks to us about their 4L Porsche 968 Billet Block product, aptly named Thor at the 2017 World Time Attack Challenge. _________________ 80 Turbo - Slightly Modified |
Posted: Sun Mar 17, 2019 5:43 pm Post subject: |
cool stuff _________________ Supercharger and EFI kits
