Re-Pressurize Fuel System
Philly924S
PostPosted: Thu Dec 08, 2016 6:42 am    Post subject: Re-Pressurize Fuel System Reply with quote
Question: Should the fuel pump run when the ignition key is in the “on” position?
Background: 1988 924 S. I am finishing my first project on this car: replacing small vacuum lines, replacing hoses under intake manifold (new gaskets), injectors out to WichHunter, new cap, rotor (just finished cutting it off with a dremel, and I’m off to Homie for new metric bolts), plugs, wires, replace the AOS seals and slotted the dipstick bracket. All in all, a nice “get to know ya” project.
I put the battery back in the car to pressurize the fuel system (to check for leaks) , turn the key to “on” and nothing from the fuel pump. Everything else seems normal, door open bell, dash lights come on, tack bounce.
I did not remove the DME relay before reconnecting the battery. Frankly, it’s in an awful location.
Do I need to engage the starter (crank the engine) to get the fuel pump running? I recall that I put the ignition key in the 0 position (everything off), Position 1 is “on”, Position 2 is “start,” after the car starts the key springs back to Position 1. Is that correct?
Thanks,
Alan
1961 356 Cabriolet
1981 911 SC
1988 924 S
PostPosted: Thu Dec 08, 2016 2:36 pm    Post subject: Reply with quote
Fuel pump doesn't run with key in "on" position unless the engine is running.
If you build a short jumper wire, you can run the fuel pump using the DME relay socket under the dash. See Clark's for details.
Philly924S
PostPosted: Thu Dec 08, 2016 10:30 pm    Post subject: Reply with quote
Thanks, Rasta, I will try the Jumper today!
1961 356 Cabriolet
1981 911 SC
1988 924 S
Philly924S
PostPosted: Fri Dec 09, 2016 8:04 am    Post subject: Re Pressurise Fuel System Update... Good News, Bad News Reply with quote
I built a DME jumper per Clark's (Thanks Rasta) and managed to remove the DME and insert the jumper leads (that's a tight spot-and my car is currently 15" in the air on 4 jack stands). The fuel pump started running and...all connections are tight, no leaks.
The fuel lines are another story. The high pressure delivery line is weeping fuel. When I started this project I noticed the fuel line hoses looked to be in poor condition. I could see cracks in the hoses, but they were intact. I suppose moving them around to remove and replace the Intake Manifold caused/contributed to the failure. I'm probably lucky, at least I saw it before I started driving. Avoided the 924 flambe.
Tomorrow I will source and buy correct length lines. And I thought I would be driving by the weekend.
1961 356 Cabriolet
1981 911 SC
1988 924 S
PostPosted: Fri Dec 09, 2016 9:00 am    Post subject: Reply with quote
Call Travis at Rennbay, he has a nice kit.
Philly924S
PostPosted: Fri Dec 09, 2016 9:54 am    Post subject: Reply with quote
Great, thanks
1961 356 Cabriolet
1981 911 SC
1988 924 S
