what are good compression numbers for a 1980 euro spec 931?
AMelbye
PostPosted: Wed Sep 28, 2016 9:22 pm    Post subject: what are good compression numbers for a 1980 euro spec 931? Reply with quote
Hi, I'm considering a 1980 eu spec 931.
It's on the other end of the country (Norway) so I got the seller to check out a few things. But I'm not sure what to make of the compression test results.
Here are the numbers:
Cyl1: 9.4bar / 136psi
Cyl2: 9.5bar / 138psi
Cyl3: 9.8bar / 142psi
Cyl4: 9.9bar / 144psi
He didn't say anything about a wet test, so I'm guessing these numbers are dry. about 5.5% difference between cyl1 and cyl4.
Are these numbers good or bad?
This is an euro spec model model year 1980 931. How high would compression be on a recent rebuild?
If this is bad. How bad is it? Engine out job?
PostPosted: Wed Sep 28, 2016 9:26 pm    Post subject: Reply with quote
Get a confirmation from other members but the numbers look good to me.
Both the value and the spread. As far as i remember difference should not be more than 10%
Lau Christophersen
PostPosted: Wed Sep 28, 2016 10:35 pm    Post subject: Reply with quote
Nearly the same numbers i got on my 931(Danish - so also euro spec). and it was driving fine.
PostPosted: Thu Sep 29, 2016 12:26 am    Post subject: Reply with quote
Good numbers.
Dutch924-racer
PostPosted: Thu Sep 29, 2016 9:51 pm    Post subject: Reply with quote
was the test cold or with warm engine ?
937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
PostPosted: Fri Sep 30, 2016 1:28 am    Post subject: Reply with quote
Surprised to see #1 lowest and #4 highest. Usually #4 gets the raw deal and usually wears first
PostPosted: Fri Sep 30, 2016 4:19 am    Post subject: Reply with quote
maybe they started counting from the other end
AMelbye
PostPosted: Fri Sep 30, 2016 6:49 am    Post subject: Reply with quote
Yeah, I'm sure he started counting from the other end.
How does it matter if the engine was cold? I'm guessing that if it was cold, warm engine numbers would probably be better?
What numbers would I get on a new rebuild?
PostPosted: Fri Sep 30, 2016 10:47 am    Post subject: Reply with quote
Yes a warm engine would be better yet, higher numbers, because tolerances decrease with heat expansion..
If you squirt oil in the cylinders it will also increase the compression numbers..
On a brand new rebuild your compression test numbers may be worse if you test it before the engine has been broken in and the rings get seated well..
80 Turbo - Slightly Modified
AMelbye
PostPosted: Fri Sep 30, 2016 7:47 pm    Post subject: Reply with quote
Let me rephrase my question: What numbers (PSI or Bar) would you get on a recently rebuilt engine that has just been broken in, and is in top condition?
PostPosted: Fri Sep 30, 2016 10:31 pm    Post subject: Reply with quote
Maybe they started measuring at #1, so at the time they were at #4 the bores maybe started to get som oil film.
I have my compression numbers written down somewhere, will take a look
PostPosted: Fri Sep 30, 2016 11:37 pm    Post subject: Reply with quote
Those numbers are good, no reason to be concerned.
White 87 924S "Ghost"
peterld
PostPosted: Mon Oct 03, 2016 3:55 pm    Post subject: Reply with quote
^ + 1. You would see similar numbers on a newly built engine.
80/81 932/8 ROW
