hdrider19
Joined: 03 May 2016 Posts: 193 Location: Catawissa Missouri(40 mi sw of St Louis)
Posted: Wed Aug 10, 2016 12:27 pm Post subject: Rennbay fuel lines |
I just got around to ordering mine today. They have 3 different kits online. I wasn't sure which kit I needed so I called them. I spoke to Travis and he was very helpful. He told me that none of the kits were right for the 924S. 85.5 and later is close but to short. Travis is making a set in the correct length for me and said he does several of these a month. I'm glad that I called first instead of just ordering the 85.5 and later kit online. You can't order these online as of now but he said they do enough of them that they will soon list these for the 924S. If you are going to replace your fuel lines CALL them. Much thanks again Travis at Rennbay! _________________ 87 924S |
Posted: Fri Aug 12, 2016 2:26 am Post subject: |
Would that apply to the 1983 944 as well? They have the same fuel line setup. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
edredas
Posted: Fri Aug 12, 2016 4:04 am Post subject: |
| Grenadiers wrote: | | Would that apply to the 1983 944 as well? They have the same fuel line setup. |
The 924S has the same fuel line routing as the early cars, but uses the late rail, requiring very long hoses. The early rail has both the damper and FPR up near the firewall, so both hoses are very short.
I hope that helps!
 _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
hdrider19
Posted: Fri Aug 12, 2016 10:15 am Post subject: |
| Grenadiers wrote: | | Would that apply to the 1983 944 as well? They have the same fuel line setup. | . They have 3 different listings for the 944 cars on their website that you can order. Only the 924S is not listed and you have to call and ask for it. $115.00 _________________ 87 924S |
hdrider19
Posted: Tue Aug 16, 2016 12:54 pm Post subject: |
I got my fuel line set in on Saturday. They are plenty long for the 924S. I will need to cut my lines down by the bottom of the firewall to get them to not be to long but the look nice. _________________ 87 924S |
hdrider19
Posted: Thu Aug 25, 2016 9:54 am Post subject: |
| Rasta Monsta wrote: | | HRider, call Rennbay for a fuel line repair kit. Much easier to install with the engine out. | . Thanks for the tip. I wouldn't want to do that with the engine in place. Install was pretty simple. I put a few drops of oil on the collar and threads before tightening. $115.00 well spent. Thanks again. Paul _________________ 87 924S |
