Power window switch on drivers side for passenger problem
RobertN
PostPosted: Wed Jul 13, 2016 3:52 am    Post subject: Power window switch on drivers side for passenger problem Reply with quote
Hi guys, never seemed to work the switch on the drivers side controlling the passenger window!! Passenger switch works well. Any suggestions as I've been all over it with my multimeter and can't figure if I've got a bad connection or something.?
Firstly the switch works as I've tried it on the drivers window and its okay.
Thanks.
Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders.
edredas
PostPosted: Wed Jul 13, 2016 6:32 am    Post subject: Reply with quote
The internal part of the switch must be oriented correctly for it to function. The fact that it operates the drivers window doesn't mean anything because the switch can be put back together incorrectly yet still operate the drivers window. That's because the two switches for the passenger side have to work together to operate, otherwise you would blow a fuse the first time you pressed them the switches opposite directions.
Here's a link to another thread. This has solved many of these issues.
http://www.924board.org/viewtopic.php?p=336707&sid=7c00c34018f4dd0eaf87dba6766b3769
I hope that helps!
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
RobertN
PostPosted: Thu Jul 14, 2016 7:24 am    Post subject: Reply with quote
Thanks bud. I'll take them apart and check as per thread.
Will let you know.
Robert.
