Bleeder Valve & Shutoff Valve Testing?
RickF
PostPosted: Tue Jul 05, 2016 6:18 am    Post subject: Bleeder Valve & Shutoff Valve Testing? Reply with quote
Is there a procedure for testing both the Bleeder Valve, (pt # 810201186A) and the Shutoff Valve, (pt # 92820108302) on an 87' 924S? I'm in the middle of a fuel tank conversion and have these valves exposed and would like to prove or replace them while they are exposed.
Thanks,
Rick
Rick
PostPosted: Tue Jul 05, 2016 7:11 am    Post subject: Reply with quote
If the ball is moving freely and the valve has no physical damage they are probably OK.
Having said that, there is a thread on Pelican discussing replacing at least one of the valves with a cheap unit.
RickF
PostPosted: Tue Jul 05, 2016 10:18 am    Post subject: Reply with quote
Thank you sir. I've been searching Pelican and can't seem to locate the thread you are referring to.
Rick
PostPosted: Tue Jul 05, 2016 3:24 pm    Post subject: Reply with quote
Linked in my plastic tank thread, I think.
