Where to find rear brake castellated nut tool?
JjyKs
PostPosted: Sat May 28, 2016 8:05 am    Post subject: Where to find rear brake castellated nut tool? Reply with quote
http://www.porsche924-944.nl/manual/Haynes/09_Braking.htm
This thing refers to special tool to remove the rear brake drums. I couldn't find it from ebay by simply searching for "vw castellated nut tool"
Ofc i could just get a regular big enough socket, but I'd rather get a right tool since the nuts are super rusted..
PostPosted: Sat May 28, 2016 8:12 am    Post subject: Reply with quote
I've always used an air impact wrench and a 6 point socket.
JjyKs
PostPosted: Sat May 28, 2016 8:46 am    Post subject: Reply with quote
My air impact wrench isn't powerful enough :/
Also, this car has been sitting outside here in Finland (snow, and a lot of rain) for 14 years and the wheels didn't even have middle caps. The nut is REALLY rusted in place. If i can't find a proper tool i will try to open it with a 6 point socket and 2 meter pipe, but if possible i would like to minimize the problems.
nickthompson
PostPosted: Sat May 28, 2016 9:33 am    Post subject: Reply with quote
P.B. Blaster
brian19600
PostPosted: Sat May 28, 2016 9:00 pm    Post subject: Reply with quote
If on ebay, try "vw rear axle nut tool".
Here is an example:http://www.ebay.com/itm/EMPI-Rear-Brake-Axle-Nut-Tool-36mm-VW-Type-1-and-3-/171109676404?hash=item27d6ee7574:m:mJewDVY8mEdDY5eyERp1ibQ&vxp=mtr
Make sure the tool matches the axle nut size..and like Nick says, start soaking it now with a good rust-busting solvent. I think the torque spec is around 270 ft/lbs.!
PostPosted: Sun May 29, 2016 2:32 am    Post subject: Reply with quote
I use a Made in China 3/4" socket drive set, using the included breaker bar, with a pipe extension. Also, to keep the wheel from spinning, a big pry bar between two wheel lugs, with one end of bar braced against ground. Might want to wear a helmet if all that sht starts to fly~!
v8carreragts
PostPosted: Sun May 29, 2016 8:52 am    Post subject: Reply with quote
The nut is 36mm the cheap Chinese 3/4" socket and breaker bar with a pipe on it will do it.
I have a 3/4" impact wrench that takes them off with ease. [/quote]
2015 AUDI Q7
2013 Chevy Cruze
JjyKs
PostPosted: Sun May 29, 2016 10:04 am    Post subject: Reply with quote
Hmm, thanks for tips. I've been spraying WD-40 to both wheels for 2 days now every time before i go driving. However the PB Blaster seems to be a lot different by the way it works. Gotta see if i can find something similar here. At least a quick google search didn't find anything similar. Only WD40 and CRC
PostPosted: Mon May 30, 2016 12:19 am    Post subject: Reply with quote
50% ATF, 50% acetone....better than any penetrant I've ever used.
