HELP!! Fuel pump relay problems!
Noahs944
PostPosted: Sat Apr 16, 2016 1:05 am    Post subject: HELP!! Fuel pump relay problems! Reply with quote
Problem: fuel pump relay (for 78 924) p/n # 477 906 059 is no longer available.
Any suggestions? Porsche has the 79 and up ones in country.
I need a relay, what are the options?
Thanks in advance!
Noahs944
PostPosted: Sun Apr 17, 2016 12:20 am    Post subject: Reply with quote
Wow... what a let down.
PostPosted: Sun Apr 17, 2016 1:46 am    Post subject: Reply with quote
Ask where you order the parts if they are compatible. They should know.
You can have the old relay rebuilt by an oldschool electronics shop. I have two turbo relays rebuilt. You can also do a hack and use a normal relay but in case of an accident the pump will still run even if the engine dies...thats a hazard. Also if you do this hack as long as the key is turned the pump will run forever regardless if the engine is working or not. I have this on both my cars since original turbo relays are also impossible to find.
sheepdog924
PostPosted: Sun Apr 17, 2016 5:09 am    Post subject: Reply with quote
Those ones are hard to find, keep an eye on eBay, .com, .uk and .de
When one comes up grab it!
Here you go,
http://www.ebay.co.uk/itm/Porsche-924-2-0-NA-1975-1978-Fuel-Pump-Relay-477906059-/331804650956?hash=item4d41192dcc:g:0GMAAOSwh-1W6Zyt
1977 2.0 NA UK
Noahs944
PostPosted: Sun Apr 17, 2016 8:56 am    Post subject: Reply with quote
Thanks fo the excellent help!
brian19600
PostPosted: Sat Apr 23, 2016 9:11 pm    Post subject: Reply with quote
Yeah I use the same relay. Keep on eye on ebay as the poster suggested. Junkyards, craigslist ads or on this board, people parting out 77-78's.
