Noahs944
Joined: 08 Dec 2015 Posts: 782 Location: Calgary, Alberta, Canada
Posted: Thu Apr 21, 2016 12:19 am Post subject: Ign Distributor hitting hood? |
| The Ign distributer is hitting the hood when cornering. Is this common? Does it represent a bad engine mount? I have already moved the hood rearward as much as possible & hammered the seam away from the distributor. But it's still contacting the Beru distributor which has lead to a broken rotor. I'm inclined to raise the hood at the back but the lines match up nicely (looks like proper fitment). Thoughts? I can't lower the engine mounts can I? |
Posted: Thu Apr 21, 2016 12:26 am Post subject: |
Wrong engine mount? Wrong dizzy? Wrong dizzy instalation...is it fully home pushed into the head? i think it should, otherwise oil would come out...but do a check.
I'd expect if an engine mount failed the engine going lower not higher.
Dont do any mods, there is no way with original parts that the dizzy makes contact to anything. _________________ Supercharger and EFI kits
Posted: Thu Apr 21, 2016 1:57 am Post subject: |
| morghen wrote: | | there is no way with original parts that the dizzy makes contact to anything |
Except if the housing is installed wrong. . .remember it has two sets of mounting holes. _________________ Toofah King Bad
Noahs944
Posted: Fri Apr 22, 2016 12:49 pm Post subject: |
| Rasta, I think you probably nailed it buddy. Many many thanks. |
Noahs944
Posted: Sat Apr 23, 2016 1:13 pm Post subject: |
IT WORKED IT WORKED!!!  |
Posted: Sat Apr 23, 2016 2:19 pm Post subject: |
durrrrr
