Differences in crankshafts ?
Kenodog
PostPosted: Sat Mar 12, 2016 1:56 am    Post subject: Differences in crankshafts ? Reply with quote
Is there a difference between the early N/A car crankshafts and the later N/A & Turbo shafts ? Just wondering because I have never seen this asked or discussed....
Leigh
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
PostPosted: Sat Mar 12, 2016 2:48 am    Post subject: Reply with quote
yea
early ones have different diameter journals...smaller.
Power Tryp
PostPosted: Sat Mar 12, 2016 3:16 am    Post subject: Reply with quote
Interesting that the PET doesn't make any distinction on different cranks other than a change up number with an A on the end.
I find it a little difficult to believe that the early motor cranks would be significantly different as the blocks are all the same and the con rods are also listing as all the same.
Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic.
PostPosted: Sat Mar 12, 2016 3:19 am    Post subject: Reply with quote
Definitely different.
Kenodog
PostPosted: Sat Mar 12, 2016 3:21 am    Post subject: Reply with quote
That's why I'm asking. I looked in PET and it only lists 1 number. Seems strange. I have a bunch of these and a few came already out of cars so I don't want to chuck something and then find out I pitched the wrong one !
Leigh
1981 931, Sabine
2024 KLX300
2024 KLX140
PostPosted: Sat Mar 12, 2016 4:00 am    Post subject: Reply with quote
79 PET shows two cranks and two sets of main bearings, 60 and 64mm.
Last 60mm crank is in engine # XK003213.
Kenodog
PostPosted: Sat Mar 12, 2016 5:45 am    Post subject: Reply with quote
So to be correct, the Turbo engines are all 64mm then ?
Leigh
1981 931, Sabine
2024 KLX300
2024 KLX140
PostPosted: Sat Mar 12, 2016 5:46 am    Post subject: Reply with quote
Affirmative!
PostPosted: Tue Mar 15, 2016 4:38 am    Post subject: Reply with quote
It would be very unlikely to find a 60mm crank here in North America. I'm going from memory, but I seem to recall that there were only 11 or so of the very first couple thousand produced that made it to North America. The rest would be in Europe.
As far as I am aware, there is no difference between the rest of the 64mm crankshafts.
