Noahs944
Joined: 08 Dec 2015 Posts: 782 Location: Calgary, Alberta, Canada
Posted: Sun Feb 07, 2016 2:07 am Post subject: What is the "modern" method of head torque? |
I'm wanting to install a head onto the block. New 12 point (cheesehead) bolts with integral washers & longer threaded portion are here.
Previously I read something in the Haynes manual about an initial torque, then running engine until warm & then retorquing.
-Is that really the deal? Sounds so messy.
Also, what is the torque value on these new head bolts?
motormouth
Posted: Sun Feb 07, 2016 7:11 am Post subject: |
| Depends on what head studs you're using. ARP says retrorquing isn't necessary. Factory says to retorque. |
Noahs944
Posted: Sun Feb 07, 2016 7:41 am Post subject: |
| Thanks. Using factory bolts not studs on an NA engine. |
motormouth
Posted: Sun Feb 07, 2016 7:44 am Post subject: |
| For factory parts, I'd use factory specs; it can't really hurt to do a retorque. |
Posted: Sun Feb 07, 2016 7:50 am Post subject: |
Depends on the headgasket used as well.
For factory parts, just go with the factory specs and tightening order.
Also for retorquing, pulling the valve cover shouldn't be messy, there shouldn't be a lot of oil in the head to cause a mess. _________________ Stefan
Noahs944
Posted: Sun Feb 07, 2016 1:22 pm Post subject: |
Thank you. Just noticed that my Haynes manuals are '81 & 83... so I will use the '83 as the more "current" reference. Cheers mates  |
Posted: Mon Feb 08, 2016 2:20 am Post subject: |
Noahs944
Posted: Mon Feb 08, 2016 3:03 am Post subject: |
Thank you Rasta! Anyone got a bulletin like that for the NA?
BTW- I compared the length of the new bolt to the old bolt. Exact same length... doesn't appear to be stretched. So maybe the old bolts can be re-used... |
Posted: Mon Feb 08, 2016 4:09 am Post subject: |
NA and 931 head are the same casting and use the same gasket, same bolts, same block, etc., so the same torquing instructions apply. Haynes will have different values because it is doesn't have the latest info from the TSBs. Use the instructions above, they are correct. Be sure to observe that there are THREE stages to tightening the bolts; and also be sure to observe the step of retightening after 60 minutes BEFORE running the engine. This is critical for proper sealing of the gasket regardless of whether you are using OEM gasket, Cometic MLS, or copper gasket. _________________ erstwhile owner of just about every 924 variant ever made |
Noahs944
Posted: Mon Feb 08, 2016 8:15 am Post subject: |
| Dan and Rasta. A big thanks to both of you. I figured there was a new method to go with the new bolt. Glad to read they are re-usable also. I coated my with anti-cease to be safe. |
jason c
Posted: Mon Feb 08, 2016 9:35 am Post subject: |
| ideola wrote: | | NA and 931 head are the same casting.... |
Dan this is not true. The 931 head is different in cast and material. The 931 is a Porsche head, the 924 was a carry over from vw/audi.
The 931 has always used a more cautious tightening routine than the n/a. The turbo spec is fine for the n/a but not vise versa. |
Lau Christophersen
Joined: 17 May 2013 Posts: 123 Location: Denmark/Copenhagen
Posted: Mon Feb 08, 2016 11:14 pm Post subject: |
Another question about head bolts...
I am making a "hybrid" between a 931 and 924, the head from the turbo and the block from the N/A.
I do have the old head bolts from the 931 and new bolts for the 924 N/A, and they are not the same, which should I use?  |
jason c
Posted: Mon Feb 08, 2016 11:46 pm Post subject: |
| Lau Christophersen wrote: | Another question about head bolts...
The new ones. |
