16V head Q
Goto page 1, 2, 3, 4  Next
bass gt
PostPosted: Tue Aug 25, 2009 10:25 pm    Post subject: 16V head Q Reply with quote
Hi Guy's
Long time no speak. Just thought i'd drop a question here. I know this revives the old 16V head saga, but was interested when i saw this head, as i don't know which VW model it's from. If the model can be found, so can the cylinder spacing etc. Whilst the oil/water galleries may not align, might this work if converted to a closed deck design?
The only info i can glean is it's a 2.0 litre KR head? Any one know this???
Steve
Front Wheel Drive is the Devil's work.
PostPosted: Tue Aug 25, 2009 11:02 pm    Post subject: Reply with quote
basicaly all MK2 VW engines starting with the 1.6 until 2.0 8v or 16v share the same block...this i got from a couple of VW guys...
bass gt
PostPosted: Tue Aug 25, 2009 11:15 pm    Post subject: Reply with quote
So how does this block compare to ours??
gegge
PostPosted: Tue Aug 25, 2009 11:28 pm    Post subject: Reply with quote
Looks like the KR, PL or ABF head. But I belive the spacing is to narrow, same as Audi I-5 I think.
The 1.8l KR has a bore of 81,0mm
The 2.0l ABF has a bore of 82,5mm
Check the GM Family II engine; 2.0l 16V Vauxhall/Opel Saab, 86mm bore. The Coscast heads are one of the best there are! Check C20XE and C20LET or search Dr. Fritz Indra who designed the head.
I think that Nissan and Mitsu also used 86mm with 16v heads. The Ford BDA is 86mm but RARE.
The best 16V head you can find is actually from Mercedes 190 2.3-16V made by Cosworth, but is oversquared by 95.50 x 80.25. BMW M3 S14 is good but oversquared as well.
I am not sure how to find the cylinder spacing except from trying/buying headgaskets.
Carl Fredrik Torkildsen
bass gt
PostPosted: Tue Aug 25, 2009 11:33 pm    Post subject: Reply with quote
Carl,
Thanks for that. Re the Ford BDA head, it is actually reversed in terms of inlet & exhaust sides.
The Vauxhall head might be interesting, as might the Toyota heads, which were actually modeled on the Ford BD series heads.
Steve
gegge
PostPosted: Tue Aug 25, 2009 11:42 pm    Post subject: Reply with quote
The C20xe/let has cylinder spacing of 93mm.
bass gt
PostPosted: Tue Aug 25, 2009 11:45 pm    Post subject: Reply with quote
Sorry, i don't have our data to hand. What the cylinder spacing on our engine?
gegge
PostPosted: Tue Aug 25, 2009 11:58 pm    Post subject: Reply with quote
The BMW 16v heads from M42 and M44 has got 84 to 86mm bore. Don´t know if M43 and M47 are of interest...
The spacing is 91mm and the I-6 engines M50 & S50 shared vital parts.
PostPosted: Wed Aug 26, 2009 12:26 am    Post subject: Reply with quote
the VW blocks are visibly shorter than ours
i'll do some measurements as i have access to some vw blocks and i think also on some 924 blocks. hope to get the data this week...but this info should be available on the internet.
Rocco R16V
PostPosted: Wed Aug 26, 2009 3:03 am    Post subject: Reply with quote
My screen name actually refers to that engine. I’m lazy and just have the same name on all the forums.
The VW 16V bore spacing is way too small to work on the Porsche motor. Sorry I dont know what it is, but the actual dimension is irrelevant.
Gegge is right KR, PL, ABF and 9A, are all 16V’s we only got the 1.8 PL and 2.0 9A here in America.
They are the same as Audi 5cyl with one less cyl. Same rods, pistons, valves ect. There is huge aftermarket support for them. These motors are very good and inexpensive to build, there are guys running well over 400hp with a turbo.
If you’re set on having a 16V you might consider swapping this motor in. it's shorter too so it could sit straight up.
"Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan
gegge
PostPosted: Wed Aug 26, 2009 3:41 am    Post subject: Reply with quote
The spacing of the 924 head is 95mm
...built like a tank!
gegge
PostPosted: Wed Aug 26, 2009 3:48 am    Post subject: Reply with quote
The Honda S2000 has a bore of 87mm. I guess that both F20C and F22C share the spacing. H22 & H23 are 87mm. Seems like all Honda are 87mm...
F22&H22&K20 have got 94mm spacing.
We are getting closer!
The Honda K20 is a killer
Insane
PostPosted: Fri Aug 28, 2009 10:21 pm    Post subject: Reply with quote
very strange topic... and very interesting as well.
- can anyone tell me what is the "closed deck design" and it's possible (dis)advantages?
PostPosted: Fri Aug 28, 2009 10:37 pm    Post subject: Reply with quote
this is an open deck...better cooling...limited HP gains...lighter..etc..
http://www.c-speedracing.com/howto/b20vtec/pics3/dsc00012.jpg
and this is a closed deck...normal cooling...not so limited HP gains...heavyer..etc..
http://www.924.org/techsection/techpics/nakedblock924.jpg
gegge
PostPosted: Sat Oct 31, 2009 9:32 am    Post subject: Reply with quote
The 2.0 liter Nissan SR (GTi-R ) has a spacing of 97mm
Page 1 of 4
