mikeycrum14
Joined: 19 Jan 2017 Posts: 110 Location: Juneau, Wisconsin
Posted: Thu Mar 09, 2017 3:00 am Post subject: Best way to repair rust holes |
I need to repair two rust holes on my 924. one is behind the passenger front tire on the side panel. (PO jacked up on pinch weld and broke through). the other is behind the rear passenger tire on the fender edge by the tire. it is small but annoying. What should i use to repair the panel? Fiberglass? _________________ 1981 924 - Alpine White, First car! LSD. - SOLD
1989 Foxbody - Oxford White Turd
1992 Miata - Freaking Red
1987 300zx Turbo - Also White
1991 Miata - White field find
1987 924S - Alpine White, Offroader Build, possible future TDI swap |
snakoil
Joined: 09 Feb 2010 Posts: 362 Location: Montreal, Canada
Posted: Thu Mar 09, 2017 10:03 pm Post subject: |
for the rear I think a great option would be to put CGT rear flares
For real I would bring the car to a frame /welder professionnal for the front damage
For the rear I would try with self adhesive body patch from the inside and then bondo on the outside
 _________________ 1979 924 NA |
mikeycrum14
Posted: Fri Mar 10, 2017 12:20 am Post subject: |
the front is just broken through the body panel. will the body patch work with an edge rust hole. like a bite mark out of the inside fender.[/img] _________________ 1981 924 - Alpine White, First car! LSD. - SOLD
