Dutch924-racer
Posted: Mon Jul 27, 2015 4:51 pm Post subject: oil pump checking/ wear limits |
I can't find any data on how te check/ measure the wear limits of the oil pump, anybody knows this ? _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Last edited by Dutch924-racer on Tue Jul 28, 2015 2:13 am; edited 1 time in total |
WEASEL149
Joined: 19 Aug 2005 Posts: 595 Location: UK, Sheffield
Posted: Mon Jul 27, 2015 6:19 pm Post subject: |
Get the endplate resurfaced. They normally clean-up after machining a couple of thou off (0.050mm).
Have a look in my build thread:-
http://www.924board.org/viewtopic.php?t=38071&postdays=0&postorder=asc&start=30
Tolerances for everything are in the FSM which I don't have with me at the moment.
I think I checked the gear tolerances with feeler gauges. _________________ 1979 UK 932 |
Dutch924-racer
Posted: Tue Jul 28, 2015 2:23 am Post subject: |
Just found it:
Oil pump:
Casing/gear wheels Axial play 0.03 - 0.07
Gearwheels Backlash of teeth 0 - 0.13
distance between casing and gears is hard the measure I think.
Backlash is the distance between the teeth of the gears I asume ? _________________ 937 trackday car
Series 2 engine
Fast road camshaft
