tach question and one about the cooling system too
maybeoneday
PostPosted: Sat Jul 25, 2015 5:45 pm    Post subject: tach question and one about the cooling system too Reply with quote
Hi Guys,
Two totally unrelated questions here hope someone can help, tried the search function but my parameters were a little complicated and couldn't find much.
Firstly my Tacho / rev counter does not work at all. From my search it appears to run off the coil can anyone give me a little better run down of how it is all connected and where to look for my issues.
The second one relates to the hose from the thermostat housing. My hose is without the bleed bung/plug (just a plain piece of hose). I am not adverse to just getting the correct one however two problems present here; the first is I cant find anyone who sells the bung, and all of the replacement hoses seem to not come with it; second, I cant seem to find a replacement hose in Australia, and the time it would take for one to come from overseas I would very much like to use to get the car running a little better. Can I unbolt the radiator overflow bottle and raise it above the piece of hose out of the thermostat to bleed the system of air, or is there some reason that this will not work.
Besides that the car is starting every time but it will not idle well at all (its ok if you keep some throttle on). I am thinking that I will need to go through the warm up stuff (WUR and AAV) and fix what I find. Also it is starting now without the CSV plugged so I need to find the fix to this too. A bit to do still, but it would really help if I could get the tach working and the cooling system in order so I can run it for longer than 90secs.
Thanks again I will post some pics soon too.
1977 924 NA Auto
maybeoneday
PostPosted: Sat Jul 25, 2015 5:47 pm    Post subject: Reply with quote
also I guess I better ask, is it preferred that I make individual thread for each individual issue I want to ask about, or is it better to keep them all in a single thread about getting my car going? I realised that I have been making single threads when an issue I needed some help with presented, and that this may not be the done thing.
1977 924 NA Auto
PostPosted: Sat Jul 25, 2015 9:09 pm    Post subject: Reply with quote
You can plug the bung with a bolt (M8 or M6, something like that?) and a hose clamp. We've had the racecar like that for a long time.
Yes, you should go through ALL the warm-up stuff.
PostPosted: Sat Jul 25, 2015 11:09 pm    Post subject: Reply with quote
You need to get a Haynes for electrical diagrams and other problems.
Not 100% accurate but apart from factory manuals will sort most problems.
maybeoneday
PostPosted: Sun Jul 26, 2015 1:51 am    Post subject: Reply with quote
both the factory manual and the haynes were supposed to turn up on friday, lets hope I see them monday.
1977 924 NA Auto
PostPosted: Sun Jul 26, 2015 3:38 am    Post subject: Re: tach question and one about the cooling system too Reply with quote
maybeoneday wrote:
Hi Guys,
Google search
site:924board.org SEARCH TERMS
80 Turbo - Slightly Modified
