kuhdad17
Posted: Thu Jul 02, 2015 9:59 am Post subject: Clutch replacement, lift engine or under car |
So I had a thought from a different thread. Since I have a cherry picker it looks like doing a clutch replacement would be much easier and faster pulling the engine compared to dropping the tranny and doing it on my back. While I'm at it I need to replace my rear main seal and might as well examine all my hoses with the engine out. Thoughts? It just seems like the easier route... _________________ '78 924 N/A |
Posted: Thu Jul 02, 2015 11:00 am Post subject: |
I'd pull and reseal the engine if you're committed to the car. Maybe rod bearings and a valve job as well. _________________ Toofah King Bad
daniel
Posted: Thu Jul 02, 2015 12:17 pm Post subject: |
I consider it easier to drop trans and pull the TT forward, but as Rasta mentioned if you are worried about seals in the engine, might be better to go that way and renew the engine while you have it out _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Joined: 29 Jul 2001 Posts: 9126 Location: Royal Oak, MI, USA
Posted: Thu Jul 02, 2015 9:39 pm Post subject: |
Good point re: pulling the engine; maybe more work than dropping the trans, but only modestly so, and you can do so many more good things to the engine too... head clean/valve job would be great, as well as cleaning (thoroughly) and resealing the oil pan would be a big benefit... _________________ Vaughan Scott
kuhdad17
Posted: Fri Jul 03, 2015 4:26 am Post subject: |
Thanks for the input, fellas. I forgot to mention I'd like to redo the gasket on the oil pan as well, so I suppose that probably helps make my decision. I just figure there's a lot of small things that need done/checked out and either way while I'm in there I ought to do them. _________________ '78 924 N/A |
