Posted: Fri Jul 31, 2015 7:20 am Post subject: Wheel Offset |
How much fender flare is needed to use 23mm offset wheels if flare is added to a standard 924 fender?. Also, How much would the track change? _________________ Mike
Posted: Fri Jul 31, 2015 7:21 am Post subject: |
Or would I run into trouble with the strut? _________________ Mike
kcoyle
jazz guy
Posted: Fri Jul 31, 2015 8:52 am Post subject: |
I like this wheel offset tool. It's quick and easy. Input your present wheel width and offset and the same for the wheels your looking to use. The tool will tell you the change in inner and outer clearances. _________________ '81/'81/'82 |
Posted: Fri Jul 31, 2015 10:49 am Post subject: |
| jazz guy wrote: | | I like this wheel offset tool. It's quick and easy. Input your present wheel width and offset and the same for the wheels your looking to use. The tool will tell you the change in inner and outer clearances. |
Awesome link thanks, bookmarked.. _________________ 80 Turbo - Slightly Modified |
Posted: Fri Jul 31, 2015 1:24 pm Post subject: |
That really helps, Thanks. _________________ Mike
Posted: Fri Jul 31, 2015 6:55 pm Post subject: |
Depends if using a 6'' rim or 10" rim. Same with rim diameter. Same with tyre width and profile. Offset is only a small part of the wheel fit equation. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
