rockhound72
Joined: 29 Oct 2012 Posts: 107 Location: Jacksonville, Arkansas
Posted: Sat May 16, 2015 3:40 am Post subject: sell or fix. '79 924 |
| Been restoring this car for about a year now. New rack and pinion, bushings, engine seals, a little of everything. Now, the hinge pillar on the driver side door is so bad, my door is literally tearing off the frame. The hinge is ok, its the frame around the hinge. What does it take to fix this or should I just give up. Hoping to get at least $1500. Its worth more from what I've done to it, but this is new territory. Im wondering if it leaked at the sunroof for years and corroded the metal or something. Never seen this before. The door drops about 4" now when I open it. Going to just park it until I figure out what to do. Any input? |
michaelodonnell123
Posted: Sat May 16, 2015 4:50 am Post subject: |
You can either pay somebody who has the skills to assist with your restoration and get it done right once and for all. Or you can try to sell yours and buy a 924 that is in excellent shape and ready to drive.
Both options cost money.
When i was shopping for my 924 I was prepared to pay from $5,000 to $8000 for an excellent example. I did not want to deal with restoration or expensive repairs. I found a low mileage 21,000 mile example and the issues that I have had have been minor- like a dirty window switch.
If I were in your shoes, I would sell the corroded 924 and buy an excellent example that is ready to go. _________________ MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500 |
ViktorTsoi
Posted: Sat May 16, 2015 5:14 am Post subject: |
Last straw on my 78. Bought another one for cheap in much better condition. Don't regret it for a minute. Since 924's are so cheap your better off paying $5k for a nice one than a $1500 one and dumping 10k into it over 5 years.
Although, I recall threads on here where members did manage to fix this problem/found someone to fix it for them. _________________ 1978 924 -parts car
1982 924 -sold
1985 944 |
rockhound72
Posted: Sat May 16, 2015 6:19 am Post subject: |
| This was in great shape for its value. Just couldn't see the corrosion since it was behind the body. Thought about a different or newer one without the snailshell and use the other for parts. They are fun cars and I have enjoyed it since I got it. |
rockhound72
Posted: Sat May 16, 2015 6:20 am Post subject: |
| I could post a pic of the damage but I do t know how on this forum[/img] |
Posted: Sat May 16, 2015 4:30 pm Post subject: |
Ask a body shop for a price quotation. How much could it be?
I mean its probably 2-3 max 4 hours of work.
Is that worth ditching your project and going trough the whole thing again and wasting more time and money?
I say fix it. Get a professional body shop to do a good kob on it.
If you dont want to pay for a local respray, you can buy exactly that paint in a spray can, order off ebay for beer money. _________________ Supercharger and EFI kits
Posted: Sat May 16, 2015 10:59 pm Post subject: |
If you're interested, I have this rust free car with the part you need. I can cut it out, leaving plenty of trim.
 _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
rockhound72
Posted: Sat May 16, 2015 11:40 pm Post subject: |
[img [/img]
Here is my door |
Posted: Sun May 17, 2015 12:10 am Post subject: |
I had that repaired on my turbo, I don't recall it being that expensive. _________________ Toofah King Bad
rockhound72
Posted: Sun May 17, 2015 3:54 am Post subject: |
| How did they repair it? The shop I was at said it would be around $4,000 at least. I figured he was jerking me around. Did you replace that part or just take off the door and re-weld it? |
Posted: Sun May 17, 2015 8:41 am Post subject: |
| rockhound72 wrote: | | The shop I was at said it would be around $4,000 at least. |
 _________________ 80 Turbo - Slightly Modified |
jason c
Posted: Sun May 17, 2015 1:32 pm Post subject: |
| Its fatigue that causes that, rust makes it happen quicker. The easiest/chapest way to repair that would be to press the mount back where it belongs & weld it back into place. A splice inside to bridge & support the two sides would help. It can be done using the weld as a gusset for strength without looking like a bubble gum mess. If I were a doing a factory looking repair, I would replace the jam. At this point it isn't that bad, I would get to it before it gets out of control. Get something on the inside to keep rust from having its way after its repaired. 4k is insane money for that repair. |
Posted: Sun May 17, 2015 4:42 pm Post subject: |
i think it happens to cars that have doors kicked while going out of the car. You know what i mean? I've especially seen overweight people do that when getting out of cars, they kick the door open making use of the door stopper in a violent way. _________________ Supercharger and EFI kits
jason c
Posted: Sun May 17, 2015 6:53 pm Post subject: |
| Definitely. Letting the door swing open on it's own with a broken stopper is another reason. It puts unintended force on the metal & fatigues it. The area where ilthe stopper mounts in the door also breaks out from fatigue when the stopper sticks or binds. |
Posted: Mon May 18, 2015 6:27 am Post subject: |
anyway, somebody has been smoking the wrong shit if they quoted 4k for a repair like that. Should be more like $200-300. _________________ Supercharger and EFI kits
