kpasko
Posted: Tue May 12, 2015 2:00 pm Post subject: 36-1 trigger wheel rec? |
Hello all, anyone have a good source for a 36-1 trigger wheel? I've got oil pump, alternator, and water pump off anyway for reasons, so figure it's prime time to put a trigger wheel on there. I can probably dupe the design from ideola that I've seen here on the boards, source some 1/8" stock that's probably lying around the shop, and cut on the waterjet, but then I'd also have to figure out some variety anti-corrosion plating too...after all that's said and done, probably easier to just spend $40 or so on one and be done with it. Has anyone tried one from diyautotune? or better yet, have an extra one of those sexy ones from Ideola laying around somewhere?
Thanks! |
Posted: Wed May 13, 2015 12:35 am Post subject: |
I have my stock of the trigger wheels and water pump spacers in IL now, if you can be patient with me, I can probably get one sent out to you. Send me an email at dan DOT beckett AT ideola DOT com and we can figure something out. _________________ erstwhile owner of just about every 924 variant ever made |
