Electrical bulb issues
Buffalorider
PostPosted: Fri Dec 12, 2014 1:17 pm    Post subject: Electrical bulb issues Reply with quote
Hello everyone...first post here. Just bought a 1977 924. Very nice condition. With some tinkering, I have it running very nicely. Now, I am moving on to the lighting issues. Hopefully some of you have been through this and can save me some time.
When I turn on just the running lights, the left side works and there is nothing on the right. Yes I replaced the bulbs. Blinkers work front and rear on the drivers side in a normal flashing cadence. When I flip the lever to the right side, ALL the lights flash front and rear (on right side) but at a higher pace to include the running lights that don't initially come on and stay on as if I were driving at dusk or dawn.
Here is what I did. I ran a jumper wire from the license plate lights to the right rear running light bulb because the license plate lights supplied some low amp power. This caused the running light to come on as well as the blinker light. Shortly thereafter, I blew both bulbs on my license plate lights.
I am constantly reading that grounds are the issues with these problems, but that does not make much sense since the lights on the drivers side work correctly. I do not think it is a relay since the 4-way flashers work. Any of you guru's have a clue where I should start?
Thanks so much for any help. This really is a nice clean original car.
12/12/14 update: I see folks are reading this but no replies. I ended up cleaning every ground connection I could find in the engine compartment and hatch back area. Even got under dash and took out fuse panel to check the grounds attached to underside of dash and no luck. I ended up splicing into the wire that supplies power to left rear tail light and connected the right rear tail light wire and now I have two lights back there. However, blinkers still flash normal on drivers side, but very fast on passenger side and ALL the bulbs work. The 4-way flashers flash at a normal pace as well. makes no sense but electrical never does.
michaelodonnell123
PostPosted: Sun Mar 22, 2015 4:22 pm    Post subject: Reply with quote
Did you get all of the electrical issues sorted out yet?
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
Buffalorider
PostPosted: Sun Mar 22, 2015 10:49 pm    Post subject: Reply with quote
No never did. replaced every bulb I could inside and out, cleaned every ground I could find and sold the car.
michaelodonnell123
PostPosted: Mon Mar 23, 2015 8:30 am    Post subject: Reply with quote
What are you driving now?
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
