Vacuum amplifier- do I need it?
brian19600
PostPosted: Sun Mar 23, 2014 4:40 am    Post subject: Vacuum amplifier- do I need it? Reply with quote
Some previous owner removed the egr valve so I'm wondering if I still need the vacuum amplifier and the the vacuum reservoir? I still need vacuum for the flap actuators for the factory a/c but I could just connect right to where the original line taps off the brake booster.
brian
ThomasJoseph315
Guest
PostPosted: Sun Mar 23, 2014 6:11 am    Post subject: Re: Vacuum amplifier- do I need it? Reply with quote
brian
Not really,.. all it does is reroute vacuum from the vacuum tank to the EGR to open during deceleration when there is no vacuum from the engine. Since you don't have an EGR, it's pointless. Everything else can be routed as you suggested.
brian19600
PostPosted: Sun Mar 23, 2014 6:18 am    Post subject: Reply with quote
Great thanks!
brian19600
PostPosted: Sat Mar 28, 2015 11:05 pm    Post subject: Reply with quote
Ok..I'm plumbing up the vacuum lines. With the amplifier removed, how does one hook up one of the lines to the distributor? Isn't it "expecting" amplified vacuum on one side of the advance? The other side goes to the throttle valve housing.
