Cooling fan fun
rockhound72
PostPosted: Sat Mar 21, 2015 8:42 am    Post subject: Cooling fan fun Reply with quote
1979 924 I replaced the coolant temp switch and checked all relays and fuses. I also hooked up the fans to see if they work, and they do. But, they will not turn on. My squirrel cage will stay on though. If I have to it in traffic when the engine is warm, I have to turn the car off. I know it isn't the thermostat. I took it out. I've replaced ALL the hoses also. Has anyone wired the fans so they stay on?
D Hook
PostPosted: Sat Mar 21, 2015 8:45 am    Post subject: Reply with quote
You say you don't have a thermostat in it at all?
'80 924 n/a SOLD
rockhound72
PostPosted: Sat Mar 21, 2015 8:50 am    Post subject: Reply with quote
Took it out because i thought it was the reason my engine was getting too hot, so I don't have one in there right now.
D Hook
PostPosted: Sat Mar 21, 2015 8:54 am    Post subject: Reply with quote
I don't understand the squirrel cage fan. Where is it located?
'80 924 n/a SOLD
rockhound72
PostPosted: Sat Mar 21, 2015 9:02 am    Post subject: Reply with quote
the squirrel cage fan is the little noise maker up by the front windshield center. Small fan enclosed by a little cage.
D Hook
PostPosted: Sat Mar 21, 2015 9:28 am    Post subject: Reply with quote
Ah got it. The later 924's actually had a squirrel cage fan. The one you're referring to is the ventilation fan for the cabin.
Does the car get hot, like into the red zone?
'80 924 n/a SOLD
rockhound72
PostPosted: Sat Mar 21, 2015 10:02 am    Post subject: Reply with quote
yep
jason c
PostPosted: Sat Mar 21, 2015 10:04 am    Post subject: Reply with quote
The "squirrel cage" fan has nothing to do with the cooling fans or overheating. Neither does the coolant temp switch.
You need to check the fan switch in the radiator.
rockhound72
PostPosted: Sat Mar 21, 2015 10:12 am    Post subject: Reply with quote
i just replaced it. still nothing. If I jump the connection, the squirrel cage comes on. Really weird huh?
jason c
PostPosted: Sat Mar 21, 2015 10:29 am    Post subject: Reply with quote
What connection? You said you replaced the temp switch. You do know the switch for the cooling fans is a different part right?
You shouldn't run a 924 without a thermostat.
rockhound72
PostPosted: Sat Mar 21, 2015 11:08 am    Post subject: Reply with quote
I replaced the temp switch at the top of the radiator. When I jumped those two connections the squirrel fan comes on. Something isn't quite right.
rockhound72
PostPosted: Sat Mar 21, 2015 11:10 am    Post subject: Reply with quote
the two pin radiator switch is the one i'm talking about. When that trips, my fans should come on.
rockhound72
PostPosted: Sat Mar 21, 2015 11:14 am    Post subject: Reply with quote
I have replaced the water pump and all its hoses as well.
PostPosted: Sat Mar 21, 2015 11:29 am    Post subject: Reply with quote
If the cockpit fan comes on when you jump the rad temp switch, but the rad fans don't come on, there is something seriously FUBAR'd with the wiring in your car.
jason c
Yes, you are correct.
You're going to have to get a wiring diagram & start hunting.
You should reinstall the thermostat or install a new one. Flush the entire cooling system while your at it. It may not be the entire problem but it probably needs it anyway.
