Mike9311
Posted: Thu Mar 12, 2015 4:02 am Post subject: Another 931 down |
I knew this one was done but its still hard once the plasma cutter is out doing its thing.
Whomever had this one I'll always wonder. The cam still has moly on it but the car was smashed so hard, on the driver front corner, it folded the roof and floor a bit. Its like they rebuilt a bunch of it and then launched it into a wall or tree immediately ?????
At least the drive train will live on in one of my shells
 _________________ 1980 931 since 1989
1981 Ideola 931 Club Sport
1982 931 Entwicklungsfahrzeug
1979 924 NA ohne 650 mit 471
1980 924 NA (R&D lightweight)
Posted: Thu Mar 12, 2015 11:22 am Post subject: |
As Hobbsie would say, kablammo.
Nice find. Please let us know if you decide to part it out... |
Posted: Thu Mar 12, 2015 8:36 pm Post subject: |
Watch for bent drive shafts and damaged bell housing. _________________ erstwhile owner of just about every 924 variant ever made |
DZGunner
Joined: 18 Nov 2014 Posts: 191 Location: Great white north
Posted: Fri Mar 13, 2015 1:52 am Post subject: |
second that on the parting _________________ 1979 924 (Daily driver EFI)
1979 924 Sebring
1977 924
1977 924 (Parts) |
Posted: Fri Mar 13, 2015 3:31 am Post subject: |
| Quote: | | Watch for bent drive shafts and damaged bell housing |
Ya know, now that I squint a little when I'm looking at the front of that, the motor looks canted to driver's left. It might be an artifact of parallax from the camera or something but I think you're right about bends in the driveline. If that engine moved left, sadly, it does not bode well for the rest of the components.
It would be interesting to see the motor mounts to see how much (if!) things have moved around...
That being said, I can see all kinds of things I want to yell "DIBBS" on  |
Mike9311
Posted: Fri Mar 13, 2015 3:59 am Post subject: |
Thanks on the thoughts guys. I'll keep it in mind for sure ...the bent stuff and the dibbs  _________________ 1980 931 since 1989
Posted: Fri Mar 13, 2015 4:24 am Post subject: |
Yeah, I helped Alex (mightymotormouth) dismantle a former Mark Johnston 931 that had been badly front-ended (must've been cursed). The bell housing was cracked / broken, as well as the front of the Audi trans housing. I seem to remember there being an issue with the torque tube, but I can't remember if it was the driveshaft or the flange on the tube itself.
In any event, something to look over carefully on any car that's sustained a hit like that. _________________ erstwhile owner of just about every 924 variant ever made |
Mike9311
Posted: Fri Mar 13, 2015 7:00 am Post subject: |
The plan is to remove the engine,trans, tube assembly as one
Then we'll see what is going on. Have to admit you have me a tad more worried that more will be damaged. It is what it is I guess _________________ 1980 931 since 1989
Posted: Fri Mar 13, 2015 7:51 am Post subject: |
Shocked/pleased/sad that I don't need dibs on anything from this car!
Mike9311
Posted: Fri Mar 13, 2015 8:16 am Post subject: |
| Rasta Monsta wrote: | Shocked/pleased/sad that I don't need dibs on anything from this car!
I can say this is the worst pic of this car especially now with the front end plasma'd off! I do see a slight roof tweek as well as in the floor and this is why the tub must go (RIP). It served someone, just not me. What is left is for parts _________________ 1980 931 since 1989
jason c
Posted: Fri Mar 13, 2015 10:14 am Post subject: |
I have an identical car (even has the same stripes), minus collision damage.
I wouldn't expect drive line damage from that type of hit. The frame horns dont appear to be moved much. The floors fold fairly easy on side impacts & the roof gets puckered when the door post moves.
How is the battery area? Lots of people looking for those. |
Mike9311
Posted: Sat Mar 14, 2015 2:59 am Post subject: |
| jason c wrote: | I have an identical car (even has the same stripes), minus collision damage.
I'll check but I think its decent.
How would that be cut out?
I want to keep the passenger fender well area so I can use the engine/well area for a header mock up/clearance jig. So I have been wondering how I want to cut this part out. Juts need it once since I can build a bench jig thereafter. _________________ 1980 931 since 1989
jason c
Posted: Sat Mar 14, 2015 10:05 am Post subject: |
| Mike9311 wrote: | | How would that be cut out? |
You'll want to save the bottom of the battery tray from the wheel well wall in front, to at least halfway up the slope towards the windshield & from the passenger sidewall under the fender to at least halfway up the slope towards the blower.
Don't cut the pan itself, whoever needs it will want the whole "pan" of the tray.
You can leave the box channel with the 3 holes & rubber plugs on the fender side attached as that usually rots out where it meets the tray. You may also want to leave the front most corner of the wheel well attached as that usually rots out also. You'll have a bowl when you're done.
Leave the battery area attached to the clip you need until you're done with your project. You can make a few bucks & help someone out who needs that battery area.
Pm me your email if you need pics of where to cut. |
Posted: Sat Mar 14, 2015 2:33 pm Post subject: |
jason c
Posted: Sat Mar 14, 2015 3:14 pm Post subject: |
| Rasta Monsta wrote: |  |
Sunroof delete  |
