Dutch924-racer
Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Tue Jan 27, 2015 6:55 am Post subject: 924 carrera GTS breather question |
The GTS has a crankcase breather on the valve cover. Does anybody know what Porsche did with the breather on the side of the block ?
http://cdn6.vierenzestig.nl/wp-content/uploads/2014/12/924-gts-clubsport-6882.jpg?379f39
 _________________ 937 trackday car
Series 2 engine
951S turbo and intercooler
Fast road camshaft
Forge recirculation valve + boost controller |
knobby
Joined: 23 May 2011 Posts: 43 Location: Cincinnati,Ohio
Posted: Sun Feb 01, 2015 5:26 am Post subject: |
Although both cars have the breather outlet in a slightly different location it would seem to me that they are venting the valve cover via an AOS and dumping into the inlet although I cant make out exactly where in the inlet wether its going to the intake air filter box (as on my 1981 931 S2)or what.
That said I would like to know why and how that affects the turbo oil drain vent which goes to the side of the cylinder head in the valve chamber?
Is this a mod which could benefit all 931's? _________________ 81 RED 931 S2(daily driver),81 WHITE 931 S2(not currently drivable).
Cincinnati,Ohio |
Posted: Sun Feb 01, 2015 8:58 am Post subject: |
You have been on this quest for awhile now!! Doing some searching, haven't seen any definitive answers for you.
http://www.924board.org/viewtopic.php?t=38872&highlight=924+gts _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
pcelenta
Joined: 16 Feb 2007 Posts: 546 Location: long island,ny
Posted: Mon Feb 02, 2015 12:06 am Post subject: |
| which white GTS is that in the photo? is it chassis number 001? or 93A0150562? I know it is not 011 because that one had a TMIC. |
Harm
pcelenta
Posted: Mon Feb 02, 2015 6:24 am Post subject: |
| Harm...you are the best! looks like photos taken at springbok...oh...and do you know which is parked right next to it??? 93A0150562! the GTS prototype! |
mark911rsr
Joined: 11 Feb 2015 Posts: 1 Location: Aberystwyth UK
Posted: Sat Feb 14, 2015 1:08 am Post subject: |
I can shed some light on this for you.
On my GTS , the crankcase breather has been capped off , as has the lower inlet to the breather 'canister' , as you can just about see in these pictures ( it's not the easiest position to get a decent photo ! )
My car was dry- sumped at the factory , hence no requirement for a breather on the crankcase as the scavenge pump pulls it back into the tank.
However I guess on the non dry sump cars , there would be a hose between these 2 outlets.
Hope this helps
Cheers
Mark
leadfoot
Posted: Sat Feb 14, 2015 9:27 am Post subject: |
nice1 thanks for sharing this...
carbon fiber GT mish mash
