DZGunner
Joined: 18 Nov 2014 Posts: 191 Location: Great white north
Posted: Mon Jan 12, 2015 7:46 pm Post subject: Fuse/relay chart |
Does anyone have a fuse/relay chart for an 80 931? I've been looking all over and cant find one, and when i do its usually for an NA car so idk if it'll be the same.
Also because my electrical system was butchered and im pulling out alot of it, i had a quick question about the starter and alternator wires. If im understanding this correctly, a large + wire comes from the battery to the starter, and from that point a new wire leads to the alternator? Or does the alternator have its own wire going to the battery +. I have a massive guage wire thats just cut and sitting in the open, and its part of the original wire harness, so it also has a couple other wires with it.
Long story short, someone jacked up my wires and i'm just going to redo them. I'll try to get some pictures in here tomorrow of my electrical woes.
Thanks guys |
DZGunner
Posted: Tue Jan 13, 2015 5:37 am Post subject: |
Someone added this random crap and cut into a lot of the factory wires as you can see.
You guys don't even want to see the interior...
kcoyle
Posted: Tue Jan 13, 2015 7:46 am Post subject: |
PM sent. _________________ 1982 931- Stock with MBC at 8psi
kcoyle
Posted: Sat Jan 17, 2015 7:24 am Post subject: |
This may help the relay situation.
DZGunner
Posted: Sat Jan 17, 2015 10:58 am Post subject: |
| Thanks this is actually what i was looking for |
leadfoot
Posted: Sun Jan 18, 2015 12:56 pm Post subject: |
I would get a haynes manual so you can access all the colour codes and schematics, you will only make things worse as the various years and areas had very different wiring.
If you want to do a serious job, rewire the car completely front to back with a new fuse panel (modern) such as painless or a universal fuse panel and do everything yourself one circuit at a time.
by the time you work out what someone else has done you could have just rewired it to factory specs.
Your other option is to go aftermarket ecu and get the wiring harness for that... this will eliminate some of the old electronic control devices and give you a fresh start.
carbon fiber GT mish mash
Posted: Mon Jan 19, 2015 4:16 am Post subject: |
Pelican has some factory diagrams in color. _________________ Toofah King Bad
