Dash lights
redporsche
PostPosted: Tue Jan 13, 2015 2:02 am    Post subject: Dash lights Reply with quote
I'm having a problem with my dash lights on my 79 924. When I found the problem I had the dash panel out. When I have the panel out my lights work(these are the ones around the speedo and tach. I pull them out quickly and can see the light going off. When I re-install the cluster and turn on the lights they don't come on. I ran a new ground from under the dash speaker but no help. Any suggestions.
I love gereatric rock.
leadfoot
PostPosted: Thu Jan 15, 2015 9:58 pm    Post subject: Reply with quote
most of the dash lights are wired in parallel so it's either a cold solder joint or most likely a broken wire,
get your multimeter out and use the continuity test tone whilst you wiggle the power supply wire white/bl stripe,
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
redporsche
PostPosted: Thu Jan 15, 2015 10:53 pm    Post subject: Dash lights Reply with quote
Thanks I'll give it a try.
