924 engine block painted?
pcelenta
PostPosted: Sat Nov 01, 2014 11:23 pm    Post subject: 924 engine block painted? Reply with quote
so every 924 I've ever owned (4 thus far) never showed any indication of the block being painted....either the paint just burned off or it was never coated...so that is the question...did the factory paint the blocks before assembly or where they bear cast iron? if they were painted then the paint was the crappiest around because as I mentioned non of my cars showed any indication of paint and all except one were below 100k miles on the odometer.
Harm
PostPosted: Sat Nov 01, 2014 11:41 pm    Post subject: Re: 924 engine block painted? Reply with quote
Image of a brand new engine on the shelf:
…hard to tell, but my vote is an unpainted engine looking at this short block.
pcelenta
PostPosted: Sun Nov 02, 2014 12:46 am    Post subject: Reply with quote
awesome pic harm! It certainly does look like raw cast iron from that photo. one would think that if the blocks were painted there would be some trace of paint somewhere...and in my years owning and playing with these cars I have yet to find even a flake.
pcelenta
PostPosted: Sun Nov 02, 2014 12:52 am    Post subject: Reply with quote
you can see some rust forming around where the oil filter goes...looks to me cast iron that had a little oil bath.
jason c
PostPosted: Sun Nov 02, 2014 1:21 pm    Post subject: Reply with quote
Definitely painted black. There was no rust on mine whatsoever when I removed it. It was a semi gloss or satin black. It was completely original when I got it. I prepped it and painted it with por15 years ago. The torque tube was also painted the same color. All of the mating surfaces were bare steel that's why the oil filter area is rusty.
Harm
PostPosted: Sun Nov 02, 2014 11:37 pm    Post subject: Re: 924 engine block painted? Reply with quote
How would they have produced the blocks?
Paint the block black before milling it down,
And complete it by instaling the freeze plugs?
Still hard to tell…
(scans by Titchati).
jason c
PostPosted: Mon Nov 03, 2014 12:22 am    Post subject: Re: 924 engine block painted? Reply with quote
Yes. Cast, paint, mill, wash & install plugs. I didn't take pics before I painted mine but it was obvious that's how it was done.
Remember, Porsche didn't manufacture the blocks and they were in several different cars.
I looked at the other 3 931's I have, all have various amounts of paint still on them. 1 is mostly rusty with some small patches and flakes of black. Another is completely black with the mounting points (machined after painting) showing surface rust.
Horizonblue
PostPosted: Mon Nov 03, 2014 2:45 am    Post subject: Reply with quote
Cool pictures
Euro 924, 1976
/P.G. Andersen
pcelenta
PostPosted: Mon Nov 03, 2014 6:01 am    Post subject: Reply with quote
Harm,
as always, you never cease to amaze me with the photos you provide! amazing, amazing pictures. thank you for sharing!
best regards,
Harm
PostPosted: Mon Nov 03, 2014 6:43 am    Post subject: Re: 924 engine block painted? Reply with quote
On the assembly images shown above it looks as if the exhaust-side engine bracket is infact unpainted bare steel;
Similar surface as the exhaust.
Why I thought the engines were bare steel?
Working on old VW type17 engines I was used to a thick layer of paint that cracks and chips over time.
The three Toofah engines I hold have long lost their layer of paint; No trace of black paint anywhere on the surface.
Maybe it is a combination of a. it's just a thin layer of paint applied by the factory, and b. the sea climate and salt on winter roads?
pcelenta wrote:
Thank you for sharing!
Cheers Paul. Keep in touch!
If anyone knows what the source/book is that carries these assembly images, I'm all ears
O/T
Proof that Toofah's aren't compiled of cardboard
(scan by danielboros)
Kind regards,
Harm.
musicalannette
PostPosted: Mon Nov 03, 2014 10:14 am    Post subject: Reply with quote
just as a quick question, is it critical you assemble the torque tube and the engine with your flies undone? poor guy looks like a doesnt even get the time after a restbreak to do em up! german efficiany at its peak - over a year you will be able to assemble 13 more torque tubes in this fasion!
tbh i found those german dungaree ideas the other guys wearing a real pain when you go to the toilet! plus it seems to get your shirt all scrunched up if your bending, so i think guy with those open flies might know what he is doing. some great shorts of the factory floor tho.
I KNEW white wall tyres were invented by Americans .....just not at Boeing.... to be fitted on the 737.....
jason c
PostPosted: Mon Nov 03, 2014 11:34 am    Post subject: Re: 924 engine block painted? Reply with quote
Harm wrote:
Maybe it is a combination of a. it's just a thin layer of paint applied by the factory, and b. the sea climate and salt on winter roads.
I agree. This seems to be in line with what I've found. My AZ car had good paint on the block. The block with the least paint/most rust was also the one exposed to the elements the most. Eventhough the paint was in good shape, it wasn't difficult to remove.
tyfighter123
PostPosted: Wed Nov 05, 2014 5:07 am    Post subject: Reply with quote
Annette is that the first thing you are looking at?
Porsche 924 1977 N/A
Mustang GT/CS 2007
Porsche 924S 1987 (parts car)(cut up and recycled)
Porsche 911S 1976
Porsche 931 1980
Porsche 931 1980 (parts car)
musicalannette
PostPosted: Thu Dec 04, 2014 12:06 am    Post subject: Reply with quote
no, no, i was trying to size up the diameter of his torque tube.
musicalannette
PostPosted: Thu Dec 04, 2014 4:44 am    Post subject: Reply with quote
i must hasten to add this was the girlfriends email address and her pc i was using at the time. please dont start sending me any personal messages thinking i am open to offers.........unless you are a ex playboy centerfold multimillionaress nymphomanic....which might happen....but to be into the 924 aswell??? i think i just dreaming.
