jeanette
Joined: 30 Aug 2008 Posts: 47 Location: US Northwest hinterland
Posted: Thu Nov 13, 2014 3:13 am Post subject: well darn... after 300K+ miles, the engine throws a piston.. |
Hi everyone,
I am in freakout mode... the trusty '79 just had major engine meltdown 300 miles from home.
Need some advice on buying a replacement engine, and where to even start.
jeanette
Totally bummed out  _________________ "person who says it cannot be done should not interrupt person who is doing it" |
Posted: Thu Nov 13, 2014 3:24 am Post subject: |
what do you mean meltdown? _________________ Supercharger and EFI kits
Posted: Thu Nov 13, 2014 3:28 am Post subject: |
That really sucks.
Have a friend with a truck and a trailer? If not, Uhaul will rent a truck and a tow dolly/trailer. Also the 924 can flat tow pretty well behind nearly anything, but it isn't a desired solution over that distance due to potential safety issue.
I'd post a Wanted post for a spare engine in the FS/W section and gather yourself an engine to rebuild. You can also look on Craigslist and http://car-part.com/ for donor engines (Note: the 76 motor has the 125hp high compression if you can find one, otherwise all of the NA motors should bolt right in).
In the meantime, I'd look at buying something cheap and reliable to drive (if you don't already) while you freshen the 924's motor. _________________ Stefan
jeanette
Posted: Thu Nov 13, 2014 3:39 am Post subject: |
All I know right now is that Duane called (he was heading in from AZ) "somewhere south of Sacramento" and said "MAJOR problem.... piston fried..."
Right now he is trying to rent a truck + trailer, and also trying to decide to go back to AZ (all the serious tools are there, but twice the distance) or keep heading up to Humboldt (300 miles of twisties)
Sounds to me that this time it is new <---(sic) engine time, as the head was less than terrific from the previous owner (MANY years ago having it shaved ... a no-no).
Sorry if this post reads like a rambling mess, but then these cars have all been so perfect, I am having a time wrapping my head around one of them being really "un-well"
jeanette _________________ "person who says it cannot be done should not interrupt person who is doing it" |
Joined: 29 Jul 2001 Posts: 9134 Location: Royal Oak, MI, USA
Posted: Thu Nov 13, 2014 3:47 am Post subject: |
Gack... my condolences...
Even if a piston's shot, and maybe a replacement head's needed - the bottom end ought to be happy. Of course, check it out, and new rings for all would be indicated - but I'd definitely be inclined to work with what you have...
Best of luck... holler if you need more suggestions/directions... _________________ Vaughan Scott
Posted: Thu Nov 13, 2014 4:19 am Post subject: |
Is this a turbo or a NA?
How can a piston be fried?
Did it run without oil?
Did it run without water?
Did it run while overheated?
This sounds like he driver is overestimating the problem/damage. _________________ Supercharger and EFI kits
Posted: Thu Nov 13, 2014 4:33 am Post subject: |
I should note that I drove mine home from Bellingham to Portland with no alternator, a cracked exhaust manifold and a shattered exhaust valve (so three cylinders). They are tough damned motors. _________________ Stefan
Posted: Thu Nov 13, 2014 4:36 am Post subject: |
| morghen wrote: | Is this a turbo or a NA?
This sounds like he driver is overestimating the problem/damage. |
If an injector is plugged and fails to provide enough fuel, you can run that cylinder lean and burn a piston fairly easily.
On mine the exhaust valve shattered, likely due to the cracked manifold allowing cold air to hit the valve? Either way, piston was fine, it just ran on three cylinders and had no compression.
Also a stuck or failed lifter/bent valve can cause problems. _________________ Stefan
jeanette
Posted: Thu Nov 13, 2014 4:44 am Post subject: |
1979 NA
Let's just say that a piston (I don't know which) got hot and bothered enough that it's no longer acting like a piston.
Fried maybe even crispy fried would be an apt description. It was more than poached or gently simmered to get to that state.
To be determined, although the oil pressure had too have been good or Duane would have shut it down. Actually he would have never set off on the trip with an oil pressure/leak issue.
Did it run without water.
To be determined, although there was no over heating. This happened at 2AM on I5 freeway speed was at 80 MPH.
No.
I really DO hope that is the case, but Duane has been rebuilding engines since he was a kid (something to do when not driving tractor on his parents farm).
If he says major, he is unfortunately ... right.
Then again, this was at 2AM....
Oh well, it will get fixed. _________________ "person who says it cannot be done should not interrupt person who is doing it" |
jeanette
Posted: Thu Nov 13, 2014 5:33 am Post subject: |
This looks likely, as the car was having some problems last year with one injector not providing enough fuel. Injector was replaced, but still there were times when the start up would be on three cylinders briefly. After the car was moving, there was no other signs of missing or pinging under load.
Might be further up line from the injectors, like a fuel line. Hopefully not the fuel distributor.
Boy when you don't know, your mind can go to dark places! _________________ "person who says it cannot be done should not interrupt person who is doing it" |
Posted: Thu Nov 13, 2014 5:43 am Post subject: |
That is some bad luck.
When i first got my 924 more than 10 years ago, i didn't know much about engines and the first month i drove it in 3.5 cyls as one of the injector was not delivering. I bought new injectors but the situation was worse, the actual problem was the fuel pump not being able to deliver.
I did drive the car sportly back then but no engine problems...not such long trips tho. _________________ Supercharger and EFI kits
Posted: Thu Nov 13, 2014 7:43 am Post subject: |
Gack - but still not unrepairable.
Yeah, sounding like one cylinder might've been lean then. Leakdown and compression tests would probably be good, I'm sure Duane knows that. Borescope would be nice, but not a cheap date. One of these days I need to get one...
So might have to run a test on the CIS when the engine's sorted, make sure all 4 injectors/lines are putting out properly... switch lines/injectors between ports if one is indeed low... and if the problem doesn't move, them time to rebuild the fuel dizzy (or have the DeLorean guy rebuild yours)... _________________ Vaughan Scott
jeanette
Posted: Fri Nov 14, 2014 12:42 pm Post subject: |
Welp.... it is ugly.
I have a photo of the pistons with one obviously destroyed.... need help with posting it for the non-squeemish.
ONE piston fried to a crisp, no, actually melted on the top, the others look fine.
Car blew a water hose after a patch of rough road (almost tore in half, so a lot of water was lost very fast).
Prior to that the car was running almost too cool for the first 600 miles of the trip.
But still, that one piston had been extremely unhappy for longer than a water hose failure/overheat event.
Duane had just replaced the head (about 700 miles ago), and the injectors were all replaced.
Two months ago, Duane checked the spray pattern of the new injectors, and they were all uniform when he also replaced the fuel pump.
Brand new Wide Band was reading 14 to 14.5. even after the failure was happening.
Duane now is worried that that was too lean (?)
He also heard a noise, more like a buzz, not pingging but thought it was a rattle in the dash, when it was probably the piston starting to go south.
Duane says there a lot here that is Bonehead Award worthy, but he wants it posted as a heads up (dontdowhatidid) anyhow.
More later when we dig into it. _________________ "person who says it cannot be done should not interrupt person who is doing it" |
jeanette
Posted: Sat Nov 15, 2014 5:20 pm Post subject: |
Cant see the picture, which piston is it? _________________ Supercharger and EFI kits
