do these strut have inserts?
paul_mck
PostPosted: Thu Oct 30, 2014 5:45 am    Post subject: do these strut have inserts? Reply with quote
If so how do you remove them? cheers
PostPosted: Thu Oct 30, 2014 7:07 am    Post subject: Reply with quote
IF they are inserts then you should be able to unscrew the top and it should have a large nut at the top.
However the later 944 struts can be rebuilt by cutting the top off and drilling a mounting hole in the bottom of the housing to hold a special insert that is held in place with a bolt.
Power Tryp
PostPosted: Sat Nov 01, 2014 1:50 am    Post subject: Reply with quote
No those are NOT the early style shocks with the inserts. You can see the cap is crimped and there is no way to get it off without cutting it.
Here's the ones that I pulled the inserts out of and while I galled them pretty bad (they were really rusty) you can see the place a special wrench can get on them to remove them.
Melanie - 1980 931
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic.
paul_mck
PostPosted: Sat Nov 01, 2014 1:53 am    Post subject: Reply with quote
super - thanks a lot!
