"green" coolant
Danski
PostPosted: Sun Oct 12, 2014 8:12 am    Post subject: "green" coolant Reply with quote
Okay so I'm begining to wonder if I am using the wrong coolant now. Basically I put in valvoline Xerex (https://valvoline.com/products/consumer-products/antifreeze-radiator-products/antifreeze/40) as it said it was safe with aluminium. But I have since heard that all 'green' coolant should not be used and that there is also a red variant of the xerex? I believe the xerex does have some silicone in it but it is low. Would it be worth changing or is this stuff actually safe?
1985 Porsche 924 NA
jason c
PostPosted: Sun Oct 12, 2014 9:54 am    Post subject: Reply with quote
The green is fine. If you do change to red "dex-cool", you'll have to completely empty & flush the system. Green & red can't be mixed, it turns to mud.
leadfoot
PostPosted: Sun Oct 12, 2014 7:11 pm    Post subject: Reply with quote
yes, plenty of green options of coolant that are aluminum safe...
as long as you read the instructions you're fine...
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Mon Oct 13, 2014 2:27 am    Post subject: Reply with quote
I put this stuff in everything:
Pentosin NF.
TYPE111
PostPosted: Mon Oct 13, 2014 9:49 pm    Post subject: Reply with quote
Green from Repco in mine.
Trust, Then Verify
Danski
PostPosted: Wed Oct 15, 2014 6:30 am    Post subject: Reply with quote
Thanks guys! That's reassuring
1985 Porsche 924 NA
