paul_mck
Posted: Thu Oct 16, 2014 11:48 pm Post subject: rear shocks - alloy vs steel trailing arms |
Hi all Im looking at buying a set of coilovers for my 88 924S with alloy rear trailing arms. The coilovers I want say the rears fit steel arms only.
is this correct? if so is it a big problem to fit them?
cheers. |
Posted: Fri Oct 17, 2014 12:24 am Post subject: |
The mounting bolt diameters are different. The Steel arms use a smaller mounting bolt, so you'll need to have the alloy bolts machined smaller or buy adapters.
The steel arms use smaller bolts because they are mounted in double sheer where the alloy arms are not, so be aware that machining the alloy bolts smaller could result in failure. Especially when used to support coil springs.
Personally, I'd skip the coil over shocks and increase spring rate properly with larger torsion bars (Look at Super Beetle off-road bars) with decent shocks (Koni's) for lower center of gravity and less potential abuse to the shock mounts. Once set properly you shouldn't need to play with ride height or corner weights more than what is available from the stock adjustments on the arms.
BTW, have you seen this thread? http://www.924board.org/viewtopic.php?t=25272 _________________ Stefan
Posted: Fri Oct 17, 2014 12:29 am Post subject: |
The lower mounting points are different. The aluminum uses a bolt, and the steel has a 'bucket' to fit the shock, and then a bolt through that. Here's a pic.
 _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
paul_mck
Posted: Fri Oct 17, 2014 12:51 am Post subject: |
bugger - I want the SPAX kit which comes in 2 forms:
18mm wide shock mount flange on front with rear alloy arms
or
20mm mount on front and steel rear arms.
I need 20mm mount on front and alloy rear arms. They wont be running coils on rear Im re-indexing the torsion bars to set height with std torsion bars.
So to fit the steel mounting struts on my alloy arms I need to use a thinner bolt, which probably wont even screw into my arms as its too small.
or try to enlarge the holes in the rear strut bottom mount to take the larger bolt I have from my alloy arms.
joy!!! |
Posted: Fri Oct 17, 2014 2:35 am Post subject: |
Opening the holes shouldn't be that big a deal. It's 12mm v 14mm I believe. _________________ Toofah King Bad
paul_mck
Posted: Fri Oct 17, 2014 2:46 am Post subject: |
I think Ill just get the steel arm kit and drill the holes out.
Sefan - the kit I want IS for the 924 but specifies steel rear arms, where my S has alloy arms. If the only difference is the mounting bolt at the bottom then enlarging it a little is perfect.
Out of interest which 924 cars came with alloy rear arms? |
Posted: Fri Oct 17, 2014 3:21 am Post subject: |
only the 924S and the 84 or 85+ 944's came with the aluminum rear arms I believe, at least in the US. Not sure about ROW.
A kit for the 944 should have the proper parts you need. No reason to specify 924 parts as they are functionally the same between the two models, the 924 is just slightly lighter.
As for opening the hole in the shock? Done that on my 924 (with 944 rear arms and 924 shocks) and its a pain in the butt requiring a reamer as a decent drill bit failed to touch the hardened metal on the shocks I was using and I didn't want to reduce the size of the bolt given the length involved could cause it to fail prematurely. _________________ Stefan
paul_mck
Posted: Fri Oct 17, 2014 9:49 pm Post subject: |
my 924 is the same as the early 944s at the front, and the later 944s at the rear. So there is no kit that satisfies both.
Plan is to buy the 924 kit for steel rear arms and have my local machine shop drill the holes out to 14mm. |
