G31 diff removal and refit
PostPosted: Sat Sep 27, 2014 4:21 am    Post subject: G31 diff removal and refit Reply with quote
So once the diff cover is removed from the side of a G31, does the diff easily pull out and be replaced by a Quaife LSD without any other stripping of the box? Haynes and FSM are no help and couldn't find anything here via Google search. Thanks
jason c
PostPosted: Sat Sep 27, 2014 10:55 am    Post subject: Reply with quote
You'll have to strip the box. Because the diff must be shimmed sided to side and the main cluster with the pinion shaft will likely need to be shimmed in or out when replacing the diff or carrier bearings, the trans will have to come apart anyway. The diff is not plug & play.
v8carreragts
PostPosted: Sat Oct 11, 2014 11:26 am    Post subject: Reply with quote
You shouldn't have to do anything to the pinion shaft. The only time you would need to change this is if you replace the shaft bearings or, of coarse, change the ring and poinion. The diff center lines will be exactly the same. But you will need to adjust the position side to side with shims and adjust the bearing preload.
2015 AUDI Q7
2013 Chevy Cruze
jason c
PostPosted: Sat Oct 11, 2014 1:56 pm    Post subject: Reply with quote
Ideally yes but it always seems to need adjustment, that's why I said likely. Should have said possibly. It depends on how much wear it has.
The races will have to pressed out & in to adjust the shim size for the carrier bearings, the gearset will need to be removed to check the diff backlash and the pinion will have to be removed to check preload so trans removal will be necessary which was carrera's concern. Sorry I didn't explain it better the first time.
PostPosted: Sat Oct 11, 2014 6:33 pm    Post subject: Reply with quote
Don't have the inclination to do a strip and build. So the Quaife will stay in its current gearbox and I'll fit that complete and test. I now have four boxes. I'll collect some necessary rebuild parts and rebuild one next year. Think I'll road test each box and see how each performs. Should be able to build one good box out of four!!
