How much does a 924 engine weight?
ThomasJoseph315
Guest
PostPosted: Tue Jul 08, 2014 12:26 pm    Post subject: How much does a 924 engine weight? Reply with quote
I think I found a spare,.. I need to find a way to haul it.
snakoil
PostPosted: Tue Jul 08, 2014 9:18 pm    Post subject: Reply with quote
it's a 4 cylinder so can't be that bad
I was able to lift up alone a Toyota 4AGE and put it in my trunk.(gotta love station wagons)
i would suggest putting a piece of wood in your trunk bottom if you don't want to brake your oem floor cardboard piece.
1979 924 NA
PostPosted: Tue Jul 08, 2014 9:58 pm    Post subject: Reply with quote
924 engine is quite heavy...you need two guys to move it, you need two strong guys to lift it 1m from the ground.
PostPosted: Tue Jul 08, 2014 10:17 pm    Post subject: Reply with quote
I think a complete long-block is somwhere in the 300-350 pound range.
nickthompson
PostPosted: Tue Jul 08, 2014 11:04 pm    Post subject: Reply with quote
I towed a 1999 Passat 90+ miles on a tow dolly with a 3.0 Ford Ranger
Ok no more posting right after I wake up. I totally missed the part about it being an engine and not a whole car.
ThomasJoseph315
Guest
PostPosted: Wed Jul 09, 2014 6:45 am    Post subject: Reply with quote
How much power could you get out of one of these n.a. 924 if it was built right?
PostPosted: Wed Jul 09, 2014 6:49 am    Post subject: Reply with quote
180hp and it will be a high strung grenade that needs race gas to survive a race weekend.
PostPosted: Wed Jul 09, 2014 6:53 am    Post subject: Reply with quote
Obviously a huge amount with a good turbo setup.. Ive seen 136kg as an official number, but that is probably a euro spec engine. Don't know how much extra crap the us version have ☺
nickthompson
PostPosted: Wed Jul 09, 2014 10:23 am    Post subject: Reply with quote
That's one of the reasons that I'm ditching mine.
PostPosted: Wed Jul 09, 2014 11:35 am    Post subject: Reply with quote
Porsche got around 450bhp in the race cars. However he wanted to know about the non-turbo engines, which are SOHC 2.0L engines with slightly crappy heads and way too much rotating mass in the bottom end. The D-production race cars were in the range of 160-180hp with very high compression, ported head, larger cam, kugelfischer injection, etc. and we're reported to be rebuilt after nearly every race weekend.
Sveina
PostPosted: Wed Jul 09, 2014 7:34 pm    Post subject: Reply with quote
I think it's more. I have lifted and carried the 944 engine without manifolds by myself, but struggled with the 924 complete engine when we were two... I was suprised at how heavy it were!
Sveina
Porsche 924 1976 RoW NA
Porsche 944 1982 RoW RSR
Porsche 951 1987 RoW 400 hp+
Porsche 951 1987 RoW 230 hp daily driver
Dodge Viper GTS 2001 soon supercharged
MB E320 CDI 4matic 2007
x 4 Porsches and lots of cars from different brands
PostPosted: Wed Jul 09, 2014 8:07 pm    Post subject: Reply with quote
Seems like my memory is correct. But engine weight is always tricky, since it depends on what you count into it, but until anything else is presented I trust the factory figures ...
Engine weight is supposed to be 166kg in the 944. According to factory numbers..
PostPosted: Wed Jul 09, 2014 10:11 pm    Post subject: Reply with quote
Yeah, between the crank and the block, it adds up quick. The rest, other than the stock cast iron exhaust manifold, isn't too bad for mass.
Regarding power - I imagine that with modern engine controls - and especially some other modern technologies that could be added in - it wouldn't be too hard to build an NA up in the range of 160-170 hp without it being a time-bomb.
PostPosted: Thu Jul 10, 2014 1:37 am    Post subject: Reply with quote
I've been reading the rules for an SCCA F Production 924 build and am not sure that we can get close to 160 HP. The restrictions include no porting beyond and inch from mating surfaces, 10.5:1 compression ratio, max cam lift of 1/2 inch and mandatory use of the stock throttle body. On the plus side, we can replace the CIS and use crank fire. Seems like air flow is the killer for HP.
PostPosted: Thu Jul 10, 2014 1:42 am    Post subject: Reply with quote
I wasn't talking about adhering to any such rules.
But yeah, there's a reason my car never turned into a Prod car...
