How do I remove this steering hub adapter?
Mars478
PostPosted: Mon Jun 02, 2014 5:20 pm    Post subject: How do I remove this steering hub adapter? Reply with quote
This may seem like a stupid question, but for the life of me I cannot figure out how to remove this steering hub adapter (circled in red) that is currently installed in my car along with the janky Grant steering wheel. Any ideas? It is installed on the splined part of the steering shaft and I really want to install the stock wheel since it will look much better.
I am trying to look for installation instructions for this wheel to see if I can reverse install it but I also can't find anything. Any ideas?
924, 82, 5 speed, dark red, 500 dollar special.
Daily: 99 ML320, 210k and still trucking.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
Mars478
PostPosted: Mon Jun 02, 2014 5:23 pm    Post subject: Reply with quote
Is a "Gear puller" necessary?
leadfoot
PostPosted: Mon Jun 02, 2014 6:19 pm    Post subject: Reply with quote
Should just slide off, friction may be causing an issue, make sure you have undone the 24mm nut though..
Stu
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
PostPosted: Tue Jun 03, 2014 1:52 am    Post subject: Reply with quote
A puller is probably necesssary. A simple bar type with a few long bolts to thread into the adapter, then tighten the center bolt.
Another thing to try would be to reinstall the wheel without the center nut and rock it back and forth to pop it off.
Mars478
PostPosted: Tue Jun 03, 2014 6:43 am    Post subject: Reply with quote
The 24mm had been removed. It seems to be on there rock solid. Will try the other tips suggested, thanks!
PostPosted: Tue Jun 03, 2014 10:06 am    Post subject: Reply with quote
Can't hurt to hit it with some penetrating oil.
jason c
PostPosted: Tue Jun 03, 2014 10:28 am    Post subject: Reply with quote
You need a steering wheel puller. If you feel like it is going to break once the puller pressure is on it, tap the side of the hub. It will pop right off.
brian19600
PostPosted: Thu Jun 12, 2014 9:15 pm    Post subject: Reply with quote
If I may add.....
Steering columns are designed to collapse so they don't go thru your chest on impact.
brian
Mars478
PostPosted: Fri Jun 13, 2014 2:23 pm    Post subject: Reply with quote
Thanks to whoever suggested the tip where I leave the wheel on and remove the center 28mm nut. That worked and my 924 is now rocking the original wheel, albeit severely dilapidated without thread around the leather, so I have to re-sew it.
