compression tester
chris79
PostPosted: Thu Jul 02, 2015 11:20 pm    Post subject: compression tester Reply with quote
I have a question, I buy a compression cilinder tester, but how can I
tighten the screw into spark plug space of 924 na ?
If I tight from rubber pipe I can't apply necessay power.
Porsche 924 2.0 na 125hp (1979) euro
Alfa Romeo Spider "Duetto" 1.6 104hp (1986) euro
PostPosted: Thu Jul 02, 2015 11:53 pm    Post subject: Reply with quote
Doesn't need to be that tight. Torque specs for spark plugs aren't that high and you aren't going to be running the engine, just turning it over a few times.
chris79
PostPosted: Fri Jul 03, 2015 12:43 am    Post subject: Reply with quote
ah ok thanks!
