Megasquirt help 924 na UK
Martin_924er
PostPosted: Tue Jun 10, 2014 12:47 am    Post subject: Megasquirt help 924 na UK Reply with quote
hi guys,
im in the process of "EFIing" my 924 na,
ive installed all the hardware and programmed the edu with the basic info
but yet it won't start... I've tried changing the cranking plus setting with no luck.
can anyone help...please...
I'm running ms2 extra with EDIS ignition, if u need any more info just ask
cheers, Martin.
Black 1985 924 lux
PostPosted: Tue Jun 10, 2014 2:18 am    Post subject: Reply with quote
Do you have your computer connected to the EFI MS2 module while you crank? No firing at all? Are you running TPS? If so, disable that and run on MAP only in case you have the wires crossed.
