Strange noises,... spoooky! You hearing what I am hearing?
ThomasJoseph315
Guest
PostPosted: Tue Aug 12, 2014 5:57 pm    Post subject: Strange noises,... spoooky! You hearing what I am hearing? Reply with quote
Anyone got a good read with pics about replacing the input and output bearings on a 4 speed manual?
I am fairly certain it's time to replace the input shaft bearings, it's not shot but you can hear noise on acceleration on 1st and 2nd and less on 3rd and 4th.
Last edited by ThomasJoseph315 on Sat Aug 16, 2014 2:28 am; edited 2 times in total
PostPosted: Tue Aug 12, 2014 11:16 pm    Post subject: Reply with quote
The FSM has the instructions and PET should have the part numbers for the service parts.
Of course ditching the 4-speed for the 5-speed isn't a hard swap and parts are a bit more readily available since they share more internally with the 944 units.
PostPosted: Tue Aug 12, 2014 11:33 pm    Post subject: Reply with quote
Does it sound like it's coming from one side or the other, down the middle? If the sound is more from left or right rear wheels, could be a carrier bearing going out.
PostPosted: Wed Aug 13, 2014 12:25 am    Post subject: Reply with quote
Not to mention it could also be the Torque Tube bearings.
PostPosted: Wed Aug 13, 2014 3:15 am    Post subject: Reply with quote
Keep the 4 speed, its faster and keeps the car original.Eyerything else is throwing money away....The early original cars are getting rare and prices do climb fast...
ThomasJoseph315
Guest
PostPosted: Wed Aug 13, 2014 12:27 pm    Post subject: Reply with quote
Well,.. It's really only sounding when I hit the gas on acceleration and moving. When I sit in the drive way with the clutch engaged with the car in neutral it doesn't do it, that kinda makes me think it might be a wheel bearing, but then again maybe it's the input shaft and only does it under load. It's really hard to hear. It sounds like a whirling sound.
ThomasJoseph315
Guest
PostPosted: Thu Aug 14, 2014 4:04 am    Post subject: Reply with quote
Can I use this for the rear wheel bearings?
http://www.harborfreight.com/fwd-front-wheel-bearing-adapters-66829.html
ThomasJoseph315
Guest
PostPosted: Fri Aug 15, 2014 12:07 am    Post subject: Reply with quote
http://www.paragon-products.com/kb_results.asp?ID=60
PostPosted: Fri Aug 15, 2014 1:36 am    Post subject: Reply with quote
http://www.clarks-garage.com/shop-manual/susp-09.htm
Also, some interesting info here:
http://www.924.org/parts/parts.htm
ThomasJoseph315
Guest
PostPosted: Sat Aug 16, 2014 1:26 am    Post subject: Reply with quote
I'm thinking I am just going to replace everything,..
Bearings (inner and outer), all bushings for trailing arms and the CV axles.
How many bushings are there total?
ThomasJoseph315
Guest
PostPosted: Sat Aug 16, 2014 2:36 am    Post subject: Reply with quote
So I crawled under the car and I grabbed the CV shafts. On the drivers side I can hear metal to metal clanging with I shake it vertical. When I twist I get the same thing. The passenger side not as much but a little is there. If these CV shafts are original on the car I'd say that's damn good engineering to last so long.
The Noises I get vary, I'm trying to figure out what is going on with the rear end. I think the whirling sound might be from drums needing to be turned/replaced. Sometimes I get a feeling the gear box maybe sloppy too, but after feeling the CV shafts I am going to start with those as they are prolly 40 years old and wouldn't hurt to replace them anyway. between all the possibilities it sounds like a jet engine reving up on acceleration, which normally would sound kinda cool, but obviously there is mechanical issues going on. So I'll start with what I see and hear and go from there. I got a feeling I'll need to replace everything eventually, but for now I start with these.
I posted a special tool for bearing race removal, but be honest,.. do I really need that thing? If I had a later 944 with a solid 2-3" bearing across the control arm I would say yes, but as anyone changed the rear bearings with hand tools?
Thanks for the help!
ThomasJoseph315
Guest
PostPosted: Tue Aug 19, 2014 1:56 pm    Post subject: Reply with quote
Turns out it was exhaust and transmission. Got a new exhaust and refreshed trans fluid and poof! problem solved!
